查看: 7082|回复: 1
[求助]请教一下关于framebuffer地址定义的问题
发表于 2006-7-24 09:42:37 | 显示全部楼层 |阅读模式
#if (LCD_TYPE==MLCD_240_320)
#define SCR_XSIZE     (480)
#define SCR_YSIZE     (640)
#define ARRAY_SIZE_G16        (SCR_XSIZE/2*SCR_YSIZE)
unsigned int (*frameBuffer16)[SCR_XSIZE/8];
void Lcd_Init(int depth)
    switch(depth)
    {case 16:
       if((U32)frameBuffer16==0)
           //The total frame memory should be inside 4MB.
           //For example, if total memory is 8MB, the frame memory
           //should be in 0xc000000~0xc3fffff or c400000~c7fffff.
           //But, the following code doesn't meet this condition(4MB)
           //if the code size & location is changed..
           frameBuffer16=(unsigned int (*)[SCR_XSIZE/8])malloc(ARRAY_SIZE_G16);
void _PutPixelG16(U32 x,U32 y,U8 c)
    if(x<SCR_XSIZE && y<SCR_YSIZE)
        frameBuffer16[(y)][(x)/8]=( frameBuffer16[(y)][x/8] & ~(0xc0000000>>((x)%8)*4) )
            | ( (c)<<((8-1-((x)%8))*4) );
在这段函数中framebuffer16所指向的首地址是0xc000000吗?在哪里有定义的吗?还是直接指向的?哪位高手能解释一下吗?
 楼主| 发表于 2006-7-27 09:59:24 | 显示全部楼层
怎么没人回我,是都不知道还是不想告诉我?
GMT+8, 2025-12-28 16:19 , Processed in 0.019407 second(s), 6 queries , Gzip On, Redis On.
