查看: 3231|回复: 6
问个关于电感Q的问题,困扰已久
发表于 2009-11-10 12:40:49 | 显示全部楼层 |阅读模式
电感Q=w*L/Rs,基本都这么算的吧
可是看了些电感产品,感觉不对啊,比如:
一个82nH电感,厂家提供的信息是:最小Q=50 at 500MHz,最大DC resistance=0.42 ohms。
如果按上面那个式子算,500MHz下最小Q=600+,这个算出来的值一看就觉得不对,但也不知道错在哪里?请大侠指教
发表于 2009-11-10 13:39:54 | 显示全部楼层
电感Q=w*L/Rs,基本都这么算的吧
可是看了些电感产品,感觉不对啊,比如:
如果按上面那个式子算,500MHz下最小Q=600+,这个 ...
dj_max 发表于 2009-11-10 12:40
the resistance of inductance is 0.42ohm at dc frequency.
when the frequency increases, the resistance of inductance will increase due to the skin effect. so the Q is much smaller than your calculation due to the loss at high frequency.
发表于 2009-11-11 08:06:46 | 显示全部楼层
The Q equation is based on a simple L-Rs model, while all actual inductors are much more complex than that.  In addition to the skin effect mentioned above, parasitic capacitance, eddy current and other effects may kick in and reduce your Q.
发表于 2009-11-11 08:22:31 | 显示全部楼层
Thank you!
发表于 2011-1-7 17:23:02 | 显示全部楼层
goooooooooooooood
发表于 2012-8-27 19:53:20 | 显示全部楼层
受教啦
发表于 2012-8-27 20:56:09 | 显示全部楼层
高频的Q有很多影响,比如eddy current,skin effect,不能用dc resistance算
GMT+8, 2025-12-9 01:28 , Processed in 0.025215 second(s), 7 queries , Gzip On, Redis On.
