楼主: 矽阳
分享一个IC613license
发表于 2010-1-28 16:23:05 | 显示全部楼层
出以下信息
*ERROR* (DB-320001): Unable to get the Cadence(R) Design Framework II license feature of "111".
不能启动。
发表于 2010-1-29 16:57:18 | 显示全部楼层
43# lyjren
You need to patch the IC613 or IC614 first before you can use the license.
发表于 2010-1-29 17:29:21 | 显示全部楼层
Thanks!
发表于 2010-1-30 19:22:59 | 显示全部楼层
thanks a lot
发表于 2010-1-30 23:49:42 | 显示全部楼层
44# SamsungMonitor
下载了613的Patch,按照readme执行出以下信息。
[cdsmgr@qxl003 ~/patch]$ ./sfk rep -bylist flexlm.pat -dir /EDA/cadence/IC613 -yes
./sfk: /lib/tls/libc.so.6: version `GLIBC_2.4' not found (required by ./sfk)
多谢
发表于 2010-2-1 08:36:28 | 显示全部楼层
47# lyjren
Please search another sfk file which compatible with your current OS.
发表于 2010-2-2 15:33:07 | 显示全部楼层
good work
发表于 2010-2-2 15:35:22 | 显示全部楼层
good work
发表于 2010-2-2 16:46:42 | 显示全部楼层
48楼,谢谢您
麻烦传个下载地址,我现在用的OS是Redhat AS4.7。
发表于 2010-2-3 11:00:36 | 显示全部楼层
51# lyjren
Please try this one. I used this without any problems.
sfk.zip (367.93 KB , 下载次数: 127 )
GMT+8, 2025-12-15 09:32 , Processed in 0.019113 second(s), 4 queries , Gzip On, Redis On.
