查看: 6283|回复: 20
招聘 RF与 Analog 设计工程师
发表于 2009-10-27 13:16:43 | 显示全部楼层 |阅读模式
请勿删。想挪挪窝的同学可以email给到下面这个邮箱,要求两年以上工作经验。工作地点:上海张江。公司为一美资企业,公司在上海的人数超过100人。有意者请直接发送简历到
amlshzj@gmail.com
1) RF designer
Job Description:
The position’s primary responsibility is to design and verify RF Transceiver ICs for wireless applications.
Job Requirements:
1.SEE or PHD with minimal 2 years of experience in RF IC design.
2.Define system and block specifications.
3.Design RFIC TX/RX blocks such as LNA, Down/Up-conversion Mixer, RF Pre-driver, PA, VCO, PLL, Filter, and PGA.
4. Experienced with the Cadence tool suite and design flow.
5. Knowledge of radio transceiver architecture and wireless communication desirable.
6.Knowledge of RF lab test equipments desirable.
2)Analog designer
Job Description:
-Design and layout of IC blocks, such as  PLL, ADC and DAC,LDO
-Simulation of RF and analog circuits and systems in Spectre/SpectreRF and Matlab
-Testing and characterization of IC blocks and chips in lab, and ATE and field environments
-IC process and package evaluation including device modeling and PDK
Job Requirements:
1.Master degree, majored in EE
2.2+ years of work experience in the related areas
3.Good knowledge in at least one of the following disciplines: low voltage/low noise OPA, high speed A/D & D/A, PLL and DPLL
发表于 2009-10-27 21:44:15 | 显示全部楼层
这是什么公司啊?
发表于 2009-10-28 10:34:37 | 显示全部楼层
关注一下
发表于 2009-10-28 14:28:57 | 显示全部楼层
招实习生吗?
 楼主| 发表于 2009-10-29 16:47:19 | 显示全部楼层
顶一下。。。。。
发表于 2009-10-30 21:09:33 | 显示全部楼层
zhao benke ?
发表于 2009-11-1 21:39:07 | 显示全部楼层
顶一下。。。。
发表于 2009-11-5 16:47:52 | 显示全部楼层
顶一下,欢迎大家
发表于 2009-11-5 17:08:09 | 显示全部楼层
关注一下!。。。。
发表于 2009-11-5 17:54:31 | 显示全部楼层
什么公司啊?
GMT+8, 2025-12-16 00:00 , Processed in 0.044236 second(s), 7 queries , Gzip On, Redis On.
