查看: 6672|回复: 17
论坛首发: powermanagment 资料.
发表于 2009-10-22 20:43:11 | 显示全部楼层 |阅读模式
1.  stability analysis of low dropout linear regulators with a pmos pass element
Low-dropout linear regulators (LDOs) have gained popularity
with the growth of battery-powered equipment.
Portable electronic equipment including cellular telephones,
laptop computers and a variety of handheld electronic
devices has increased the need for efficient voltage regulation
to prolong battery life. Texas Instruments offers
several LDO products designed with PMOS pass transistors
with very low dropout voltage. Compared to the NPN
linear regulator, the LDO regulator can control its output
voltage with much less headroom. The NPN regulator
requires about 2 V of headroom while the LDO requires
less than half a volt...
2. Understanding noise in linear regulators.pdf
Types of noise in analog circuits may include thermal,
flicker, and shot noise, among others. In an LDO application,
noise is sometimes confused with power supply ripple
rejection (PSRR). Many times the two are lumped together
and loosely called “noise” just because both cause unwanted
signals on the output. This is incorrect. PSRR refers to
the amount of ripple on the output coming from ripple on
the input. Noise, on the other hand, is purely a physical
phenomenon that occurs with transistors and resistors
(capacitors are noise-free) on a very fundamental level.
 楼主| 发表于 2009-10-22 20:44:55 | 显示全部楼层
需要的朋友可以看看。.
stability analysis of low dropout linear regulators with a pmos pass element.pdf
240.58 KB, 下载次数: 49 , 下载积分: 资产 -2 信元, 下载支出 2 信元
232.73 KB, 下载次数: 40 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-10-23 06:09:58 | 显示全部楼层
感謝分享...終於有首發了
发表于 2009-10-23 15:34:38 | 显示全部楼层
thanks
发表于 2009-10-23 23:23:05 | 显示全部楼层
kankan ,you sha xin dongxi
发表于 2009-10-24 06:18:41 | 显示全部楼层
Just a few application notes from TI.
发表于 2009-10-24 15:12:37 | 显示全部楼层
谢谢分享
发表于 2009-10-24 15:40:33 | 显示全部楼层
直接网上搜就能找到了
发表于 2009-10-24 23:20:54 | 显示全部楼层
感謝分享
发表于 2009-10-26 05:44:29 | 显示全部楼层
感謝分享
GMT+8, 2025-12-23 23:20 , Processed in 0.033945 second(s), 7 queries , Gzip On, Redis On.
