查看: 6209|回复: 20
jssc的pll最新文章
发表于 2009-10-7 09:09:10 | 显示全部楼层 |阅读模式
1. A Low-Noise Wideband Digital Phase-Locked Loop Based on a Coarse–Fine Time-to-Digital Converter With Subpicosecond Resolution
Lee, M.; Heidari, M. E.; Abidi, A. A.;
Solid-State Circuits, IEEE Journal of
Volume 44,  Issue 10,  Oct. 2009 Page(s):2808 - 2816
Digital Object Identifier 10.1109/JSSC.2009.2028753
Summary: This paper presents the design of a digital PLL which uses a high-resolution time-to-digital converter (TDC) for wide loop bandwidth. The TDC uses a time amplification technique to reduce the quantization noise down to less than 1 ps root mean.....
2. An FIR-Embedded Noise Filtering Method for $Delta Sigma$ Fractional-N PLL Clock Generators
3. A Wideband PLL-Based G/FSK Transmitter in 0.18 $mu$m CMOS
Tsung-Hsien Lin; Yao-Hong Liu;
Volume 44,  Issue 9,  Sept. 2009 Page(s):2452 - 2462
Digital Object Identifier 10.1109/JSSC.2009.2022994
Summary: A wideband phase-locked loop (PLL)-based G/FSK transmitter (TX) architecture is presented in this paper. In the proposed TX, the G/FSK data is applied outside the loop; hence, the data rate is not constrained by the PLL bandwidth. In addition, the PL.....
AbstractPlus | Full Text: PDF(2447 KB)    IEEE JNL
4. Minimizing the Supply Sensitivity of a CMOS Ring Oscillator Through Jointly Biasing the Supply and Control Voltages
getPDF.pdf
1.28 MB, 下载次数: 85 , 下载积分: 资产 -2 信元, 下载支出 2 信元
getPDF2.pdf
1.5 MB, 下载次数: 76 , 下载积分: 资产 -2 信元, 下载支出 2 信元
getPDF3.pdf
2.39 MB, 下载次数: 94 , 下载积分: 资产 -2 信元, 下载支出 2 信元
getPDF4.pdf
2.07 MB, 下载次数: 104 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-10-7 09:45:11 | 显示全部楼层
好东东啊
发表于 2009-10-7 18:31:16 | 显示全部楼层
英文版本的吗?
发表于 2009-12-18 09:33:58 | 显示全部楼层
dfasfsaf
发表于 2009-12-18 10:20:58 | 显示全部楼层
2# NANHU_BRUCE
还有中文的?
发表于 2010-1-23 12:54:50 | 显示全部楼层
thanks
发表于 2010-1-23 21:38:39 | 显示全部楼层
thanks
发表于 2010-3-16 20:58:30 | 显示全部楼层
thanks
发表于 2010-3-16 21:52:05 | 显示全部楼层
thanks
发表于 2010-3-16 23:17:50 | 显示全部楼层
thanks
GMT+8, 2025-12-26 22:14 , Processed in 0.056574 second(s), 4 queries , Gzip On, Redis On.
