楼主: meged
Mentor dft & calibre 2009 - LICGEN
发表于 2009-9-14 16:38:08 | 显示全部楼层
试一下。。。。。。。。。。。
发表于 2009-9-14 16:38:52 | 显示全部楼层
先拿来试试能不能用!
发表于 2009-9-14 16:48:38 | 显示全部楼层
里面的说明好像是calibre2008.2
Mentor Env. var setup:
# Mentor env:
setenv MGC_HOME /usr/export/applic/mentor/dft_v8.2007_2.10
setenv CALIBRE_HOME /usr/export/applic/mentor/cal_2008.2_11.12
发表于 2009-9-15 15:43:32 | 显示全部楼层
看看是否有效
 楼主| 发表于 2009-9-15 19:36:12 | 显示全部楼层
ECC patch tested & works !!!
发表于 2009-9-15 19:52:05 | 显示全部楼层
can you please explain in more details how to execute the ecc patch? and in what files?
 楼主| 发表于 2009-9-16 03:45:40 | 显示全部楼层
The patch attached above is an explanation (not an executible):
1. Use IDA (dis-assembler) to open & dis-assemble the Mentor FlexLM daemon (or other executible)
2. Use the detailed explanation to trace the '_l_pubkey_verify' routine
3. Define an identifying string to locate where to patch (also described in details)
4. Serach the string in the entire Mentor install directory - using SFK tool 'search' command
5. This wil give you all the files in Mentor install directory which must be patched
6. Patch manually all files (with some HEX editor), or use SFK tool to 'search & replace'
7. Done.
发表于 2009-9-16 09:21:27 | 显示全部楼层
真的可以用嗎?先下載來試看看
发表于 2009-9-16 09:26:44 | 显示全部楼层
所以應該還是要破解ecc
发表于 2009-9-16 09:50:22 | 显示全部楼层
谢谢啊O(∩_∩)O哈哈~
GMT+8, 2025-12-30 04:19 , Processed in 0.017844 second(s), 5 queries , Gzip On, Redis On.
