查看: 6084|回复: 0
Jewelcrafting Guide - wow gold
发表于 2009-7-19 21:44:17 | 显示全部楼层 |阅读模式
Jewelcrafting is a primary skill, meaning that it counts towards your two profession limit. Keep this in mind when you take up Jewelcrafting, as unlearning it to take up another profession will reset your knowledge of Jewelcrafting to zero should you choose to pick it up again.
Jewelcrafting is a production tradeskill, meaning that it takes unrefined items gathered from the world (gems, stone, metals) and wow gold turns them into refined items (refined gems, necklaces, figurines, etc.). To get the most out of Jewelcrafting you will have to take up Mining.
Be sure to check out our Profession Forums should you require any additional help with Jewelcrafting! Our community is always looking to help anyone with any questions they should have.
            Getting Started
            Rank Name
            Required
            Level
            Skill Levels
Apprentice
            5
            1 - 75
Journeyman
            10
            50-150
Expert
            20
            125-225
Artisan
            40
            200-300
Master (Burning Crusade)
            50
            300-375
To begin, seek out a <Journeyman Jewelcrafter> in order to learn the profession. The best locations to find one would the Exodar (for the Alliance) and Silvermoon City (for the Horde),wow gold, both requiring the expansion. When you arrive at the city, simply speak with a guard and ask where the Jewelcrafting profession trainer is located and they will mark your map.
Once you have found a trainer, interact with them (right click) and choose to train Apprentice Jewelcrafting.  Congratulations! You are officially a Jewelcrafting! I highly suggest taking up Mining at the same time as you will need it to prospect gems from ore and to gather materials necessary to create items with Jewelcrafting.
Any class and race can pick up Jewelcrafting and gain a benefit, although certain ranks require certain levels. Not only that, but to obtain the final rank (Master) one must venture into Outland which requires a character of at least level 58.
Any character of any class or race can pick up Journeyman Jewelcrafting as long as their account is "The Burning Crusade" enabled. To advance past that you will have to have the required level. The last level, Master, currently is available to level 50 players but the only known trainers are in Outland (requiring level 58).
            Choosing a Second Profession
There is no need to list the other professions as only one goes with Jewelcrafting. That one profession is Mining. Jewelcrafting uses metals and gems found from various metal nodes all around the land and it will always benefit whenever you can obtain the materials yourself. Not only that, but having Mining allows for the prospecting skill to be used.
            Jewelcrafting
Jewelcrafting is a rather easy skill to use. Simply open your Spellbook and locate “Jewelcrafting”. From here select what you wish to craft then choose “Create”. You can use the slider to craft multiples at the same time, if you wish. If you have the available materials then a bar will come up letting you know the item is buy wow gold currently being created. If you wish to cancel during this time simply move your character around. If it fails due to movement then you will loose no materials.
Skilling up Jewelcrafting is easy. If it&rsquo;s colored Orange then you&rsquo;ll gain a skill point in Jewelcrafting. If it&rsquo;s colored Yellow then you&rsquo,cheap wow gold;ll have a decent change to increase in skill. If it&rsquo;s colored Green then you&rsquo;ll have a low chance to increase in skill. Grey items do not give skill points.
Quite a few Jewelcrafting items are “Bind on Pickup”, which means that the items created are only for you. This makes it a worthy skill to have when you&rsquo;re leveling because you&rsquo;ll have some useful items (rings, necklaces, etc.) and have Mining which is already a great source of profit.
A quick note, some items may require a "Jeweler's Kit" and/or a "Simple Grinder&quot,buy wow gold;. These items are available for sale by certain Jewelcrafter trainers and suppliers
            Gems and Jewelry
Gems are found two ways. One is that they can be crafted by taking a gem and refining it with the Jewelcrafting skill. The second is to purchase it from various NPC vendors (who may or may not be controlled by reputation). The first method is great for producing very fine refined gems from gems while the second is great to put into filler gear or anything you find that needs a gem but doesn&rsquo;t need something overly expensive.
Your basic gems currently can increase the following:
    Attack Power
    Strength
    Parry
    Dodge
    Healing
    Spell Damage
    Spell Critical Rating
    Hit Rating
    Critical Strike Rating
    Intellect
    Defense Rating
    Resilence
    Stamina
    Spirit
    Spell Penetration
    Mana every 5 sec
Combination of gems can cheap wow gold include resists, run speed buffs, chance to stun or restore health on melee attack, reduced threat, and more. There are advanced colors, such as orange, green, and purple that combine two bonuses (by mixing colors). Meta gems are combinations of lots of gems and include the most powerful bonuses.
Jewelry comes in various rings, necklaces, trinkets and statues. The new item in this list, statues, is similar to the Shaman&rsquo;s totems and provides a pulsing heal on the Jewelcrafter for a short period of time. The rings, necklaces, and trinkets are very powerful and their low level creations are extremely viable.
Related Articles:
   Priest changes in build 10072 - buy wow gold
   Priest Class Guide - world of warcraft gold
GMT+8, 2025-12-29 05:01 , Processed in 0.013933 second(s), 6 queries , Gzip On, Redis On.
