查看: 12807|回复: 2
LWIP API问题!!!
发表于 2006-4-12 08:21:50 | 显示全部楼层 |阅读模式
请大家帮帮忙!!!
LWIP/api_lib.c代码:
netconn *netconn_new_with_proto_and_callback(enum netconn_type t, u16_t proto,
                                   void (*callback)(struct netconn *, enum netconn_evt, u16_t len))
  struct netconn *conn;
  struct api_msg *msg;
  conn = memp_malloc(MEMP_NETCONN);
  if (conn == NULL) {
    return NULL;
  conn->err = ERR_OK;
  conn->type = t;
  conn->pcb.tcp = NULL;
  if ((conn->mbox = sys_mbox_new()) == SYS_MBOX_NULL) //提示:SYS_MBOX_NULL有问题?
    memp_free(MEMP_NETCONN, conn);
    return NULL;
  conn->recvmbox = SYS_MBOX_NULL;
  conn->acceptmbox = SYS_MBOX_NULL;
  conn->sem = SYS_SEM_NULL;        提示:SYS_SEM_NULL有问题?
  conn->state = NETCONN_NONE;
  conn->socket = 0;
  conn->callback = callback;
  conn->recv_avail = 0;
  if((msg = memp_malloc(MEMP_API_MSG)) == NULL) {
    return NULL;
  msg->type = API_MSG_NEWCONN;
  msg->msg.msg.bc.port = proto; /* misusing the port field */
  msg->msg.conn = conn;
  api_msg_post(msg);
  sys_mbox_fetch(conn->mbox, NULL);
  memp_free(MEMP_API_MSG, msg);
  if ( conn->err != ERR_OK ) {
    return NULL;
  return conn;
编译器是用的ADS1.2。
这是编译出错的提示:
Error   : C2456E: undeclared name, inventing 'extern int SYS_MBOX_NULL'
api_lib.c line 213
Error   : C2456E: undeclared name, inventing 'extern int SYS_SEM_NULL'
api_lib.c line 219
Error   : C2456E: undeclared name, inventing 'extern int SYS_ARCH_TIMEOUT'
api_lib.c line 282
api_msg.c line 51
api_msg.c line 146
Error   : C2456E: undeclared name, inventing 'extern int ENOMEM'
sockets.c line 78
Error   : C2456E: undeclared name, inventing 'extern int ENOBUFS'
sockets.c line 79
Error   : C2456E: undeclared name, inventing 'extern int ECONNABORTED'
sockets.c line 80
Error   : C2456E: undeclared name, inventing 'extern int ECONNRESET'
sockets.c line 81
Error   : C2456E: undeclared name, inventing 'extern int ESHUTDOWN'
sockets.c line 82
Error   : C2456E: undeclared name, inventing 'extern int ENOTCONN'
sockets.c line 83
Error   : C2456E: undeclared name, inventing 'extern int EINVAL'
sockets.c line 84
Error   : C2456E: undeclared name, inventing 'extern int EIO'
sockets.c line 85
Error   : C2456E: undeclared name, inventing 'extern int EHOSTUNREACH'
sockets.c line 86
Error   : C2456E: undeclared name, inventing 'extern int EADDRINUSE'
sockets.c line 87
Error   : (Serious) C2432E: non-constant initialiser
sockets.c line 78
sockets.c line 79
sockets.c line 80
sockets.c line 81
sockets.c line 82
sockets.c line 83
sockets.c line 84
sockets.c line 85
sockets.c line 86
sockets.c line 87
Error   : C2456E: undeclared name, inventing 'extern int EWOULDBLOCK'
sockets.c line 372
Error   : C2456E: undeclared name, inventing 'extern int EFAULT'
sockets.c line 980
Error   : C2456E: undeclared name, inventing 'extern int ENOPROTOOPT'
sockets.c line 1015
Error   : C2456E: undeclared name, inventing 'extern int ENOSYS'
sockets.c line 1358
 楼主| 发表于 2006-4-12 08:23:41 | 显示全部楼层
LWIP API问题!!!
自己先顶一下....
请大家帮帮忙...
小弟先谢过啦!!!
发表于 2010-1-25 14:12:48 | 显示全部楼层
thank you
GMT+8, 2025-12-16 04:45 , Processed in 0.012725 second(s), 3 queries , Gzip On, Redis On.
