查看: 2431|回复: 9
Overview of the 3GPP Long Term Evolution Physical Layer.pdf
发表于 2009-6-30 14:31:04 | 显示全部楼层 |阅读模式
Overview of the 3GPP Long Term Evolution Physical Layer.pdf (363.53 KB , 下载次数: 32 )
发表于 2009-7-1 18:46:11 | 显示全部楼层
讲的什么啊?
发表于 2009-7-8 02:04:03 | 显示全部楼层
Thanks  a lot !!!!!!!!!
发表于 2009-7-31 10:00:11 | 显示全部楼层
thanks
发表于 2009-8-1 06:30:02 | 显示全部楼层
have a look
发表于 2009-8-1 06:32:33 | 显示全部楼层
Overview
Long Term Evolution (LTE) is the next step forward in cellular 3G services. Expected in the 2008 time frame, LTE is a
3GPP standard that provides for an uplink speed of up to 50 megabits per second (Mbps) and a downlink speed of up
to 100 Mbps. LTE will bring many technical benefits to cellular networks. Bandwidth will be scalable from 1.25 MHz to 20
MHz. This will suit the needs of different network operators that have different bandwidth allocations, and also allow
operators to provide different services based on spectrum. LTE is also expected to improve spectral efficiency in 3G
networks, allowing carriers to provide more data and voice services over a given bandwidth.
This technical white paper provides an overview of the LTE physical layer (PHY), including technologies that are new to
cellular such as Orthogonal Frequency Division Multiplexing (OFDM) and Multiple Input Multiple Output (MIMO) data
transmission.
发表于 2010-1-1 19:12:38 | 显示全部楼层
很好,继续。
发表于 2010-1-1 21:35:20 | 显示全部楼层
多謝分享
发表于 2010-1-1 21:36:51 | 显示全部楼层
謝謝你的分享阿
发表于 2025-2-8 04:57:12 来自手机 | 显示全部楼层
谢谢分享
GMT+8, 2025-11-27 21:54 , Processed in 0.022477 second(s), 4 queries , Gzip On, Redis On.
