楼主: roy05
hspice 2009 03 for win + hspice_RF + 圖文並茂破解, 已經重新整理再度上傳!!!
发表于 2009-10-24 15:29:22 | 显示全部楼层
1# roy05
谢谢!
发表于 2009-10-24 15:39:42 | 显示全部楼层
谢谢分享!
发表于 2009-10-24 15:42:32 | 显示全部楼层
谢谢分享
发表于 2009-10-24 16:02:29 | 显示全部楼层
Hspice is a device level circuit simulator. Hspice takes a spice file as input and produces output describing the requested simulation of the circuit. It can also produce output files to be used by the AWAVES post processor.
发表于 2009-10-24 16:05:23 | 显示全部楼层
The general procedure for analyzing a circuit is to use an editor ( vi, emacs, etc.) to create an
input file, run HSPICE to generate graph and hardcopy data files, and run MetaWaves to view,
customize, and print the resulting graphs. It is usually easier to start with an example input file
(such as those at the end of this handout) and modify it to match the desired circuit. The commands
found in the example input files and summary in this handout are sufficient to perform simple simulations.
For more sophisticated analyses consult the HSPICE USERS MANUAL.
发表于 2009-10-26 05:28:14 | 显示全部楼层
To run HSPICE, you must first open an X-window. The procedure for opening an X-window
varies depending on the type of computer you are using. If you have questions, read the section on
Workstation Basics later in this handout.
发表于 2009-10-26 05:30:44 | 显示全部楼层
Before running HSPICE, users should execute the command
source /usr/class/ee/DOT.cshrc
This will set your path correctly and initialize some environment variables (put this line in your
.cshrc file to avoid having to retype it each time you run HSPICE).
发表于 2009-10-26 05:35:15 | 显示全部楼层
You may also want to customize some of the HSPICE control options assigned in the configuration
file meta.cfg. At run time, HSPICE looks for a configuration file, searching first in the
user's home directory, and then in the HSPICE installation directory (which contains a default version).
If you wish to customize your configuration, copy the default meta.cfg file to your home
directory using the command
发表于 2009-10-26 05:36:58 | 显示全部楼层
You can then use an editor to make the desired modifications (such as setting the prtdefault variable to sweet1 (sweet1 can print on both sides of the page, so you won't go through your quota as fast)).
发表于 2009-10-26 05:40:01 | 显示全部楼层
Once you have opened an X-window, the procedure for running HSPICE is essentially the
same on the various workstations. However, there are different versions of HSPICE installed on
the different workstations, so you may notice slight differences.
To run HSPICE, enter the command
hspice filename.hsp > filename.lis
GMT+8, 2025-12-20 05:21 , Processed in 0.020359 second(s), 2 queries , Gzip On, Redis On.
