查看: 1861|回复: 1
[原创] 谁会dsp和ccs帮个忙好吗??
发表于 2009-5-24 11:51:57 | 显示全部楼层 |阅读模式
谁会dsp和ccs帮个忙好吗??        为什么我的c程序在turboc中结果正确  在ccs中就不行了呢??
这是c程序 下面还有cmd文件
要怎么修改一下 才对呢??
最好能给我一个能调试成功的工程文件
#include "math.h"
struct compx
{ double real;
  double imag;
} compx ;
struct compx EE(struct compx b1,struct compx b2)
struct compx b3;
b3.real=b1.real*b2.real-b1.imag*b2.imag;
b3.imag=b1.real*b2.imag+b1.imag*b2.real;
return(b3);
void FFT(struct compx *xin,int N)
int f,m,LH,nm,i,k,j,L;
double p , ps ;
int le,B,ip;
float pi;
struct compx w,t;
LH=N/2;
f=N;
for(m=1;(f=f/2)!=1;m++){;}
nm=N-2;
j=N/2;
for(i=1;i<=nm;i++)
if(i<j){t=xin[j];xin[j]=xin;xin=t;}
k=LH;
while(j>=k){j=j-k;k=k/2;}
j=j+k;
for(L=1;L<=m;L++)
le=pow(2,L);
B=le/2;
pi=3.14159;
for(j=0;j<=B-1;j++)
   p=pow(2,m-L)*j;
   ps=2*pi/N*p;
   w.real=cos(ps);
   w.imag=-sin(ps);
   for(i=j;i<=N-1;i=i+le)
      ip=i+B;
      t=EE(xin[ip],w);
      xin[ip].real=xin.real-t.real;
      xin[ip].imag=xin.imag-t.imag;
      xin.real=xin.real+t.real;
      xin.imag=xin.imag+t.imag;
return ;
#include <math.h>
#include <stdlib.h>
float  result[256];
struct  compx s[256];
int   Num=8;
const float pp=3.14159;
main()
int i;
for(i=0;i<8;i++){
s.real=sin(pp*i/4);
s.imag=0;
FFT(s,Num);
for(i=0;i<8;i++)
printf("%.4f",s.real);
printf("+%.4fj\n",s.imag);
result=sqrt(pow(s.real,2)+pow(s.imag,2));
for(i=0;i<8;i++)
printf("%.4f\n",result);
/* COMMAND FILE FOR LINKING PROGRAMS TO RUN ON LEAD SIMULATOR */
-c
-x
-stack 100
-heap  100
/* -l rts500.lib */
MEMORY
   PAGE 0:
      PROG: origin = 0x1400, length = 0xFF80
   PAGE 1:
      DATA: origin = 0x1400, length = 0xFF80  /*mmr and internal dual access scratch, RAM */
SECTIONS
   .text   PAGE 0
   .cinit  PAGE 0
   .switch PAGE 0
   .bss    PAGE 1
   .const  PAGE 1
   .sysmem PAGE 1
   .stack  PAGE 1
   .cio    PAGE 1
发表于 2009-5-24 12:53:27 | 显示全部楼层
怎么没人回答
GMT+8, 2025-12-15 03:38 , Processed in 0.013985 second(s), 6 queries , Gzip On, Redis On.
