查看: 2914|回复: 14
【Wiley 2004】Detection Algorithms for Wireless Communications
发表于 2009-5-15 09:20:24 | 显示全部楼层 |阅读模式
《Detection Algorithms for Wireless Communications》【原书作者】: Gianluigi Ferrari, Giulio Colavolpe, Riccardo Raheli
【ISBN 】: 0470858281
【页数 】:426
【出版社】 :Wiley
【出版日期】:2004-10-29
【文件格式】:PDF
【摘要或目录】:
Wireless channels are becoming more and more important, with the future development of wireless ad-hoc networks and the integration of mobile and satellite communications.  To this end, algorithmic detection aspects (involved in the physical layer) will become fundamental in the design of a communication system.
This book proposes a unified approach to detection for stochastic channels, with particular attention to wireless channels. The core idea is to show that the three main criteria of sequence detection, symbol detection and graph-based detection, can all be described within a general framework. This implies that a detection algorithm based on one criterion can be extended to the other criteria in a systematic manner.
Presents a detailed analysis of statistical signal detection for digital signals transmitted over wireless communications
Provides a unifying framework for different signal detection algorithms, such as sequence detection, symbol detection and graph-based detection, important for the design of modern digital receivers operating over mobile channels
Features the hot topic of graph-based detection
Detection Algorithms for Wireless Communications represents a novel contribution with respect to the current literature, with a unique focus on detection algorithms, as such it will prove invaluable to researchers working in academia and industry and in the field of wireless communications, as well as postgraduate students attending advanced courses on mobile communications.
Preface.
Acknowledgements.
List of Figures.
List of Tables.
1. Wireless Communication Systems.
1.1 Introduction.
1.2 Overview of Wireless Communication Systems.
1.3 Wireless Channel Models.
1.4 Demodulation, Detection, and Parameter Estimation.
1.5 Information Theoretic Limits.
1.6 Coding and Modulation.
1.7 Approaching Shannon Limits: Turbo Codes and Low Density Parity Check Codes.
1.8 Space-Time Coding.
1.9 Summary.
1.10 Problems.
2. A General Approach to Statistical Detection for Channels with Memory.
2.1 Introduction.
2.2 Statistical Detection Theory.
2.3 Transmission Systems with Memory.
2.4 Overview of Detection Algorithms for Stochastic Channels.
2.5 Summary.
2.6 Problems.
3. Sequence Detection: Algorithms and Applications.
3.1 Introduction.
3.2 MAP Sequence Detection Principle.
3.3 Viterbi Algorithm.
3.4 Soft-output Viterbi Algorithm.
3.5 Finite-Memory Sequence Detection.
3.6 Estimation-Detection Decomposition.
3.7 Data-Aided Parameter Estimation.
3.8 Joint Detection and Estimation.
3.9 Per-Survivor Processing.
3.9.1 Phase-Uncertain Channel.
3.10 Complexity Reduction Techniques for VA-based Detection Algorithms.
3.11 Applications to Wireless Communications.
3.12 Summary.
3.13 Problems.
4. Symbol Detection: Algorithms and Applications.
4.1 Introduction.
4.2 MAP Symbol Detection Principle.
4.3 Forward-Backward Algorithm.
4.4 Iterative Decoding and Detection.
4.5 Extrinsic Information in Iterative Decoding: a Unified View.
4.6 Finite-Memory Symbol Detection.
4.7 An Alternative Approach to Finite-Memory Symbol Detection.
4.8 State Reduction Techniques for Forward-Backward Algorithms.
4.9 Applications to Wireless Communications.
4.10 Summary.
4.11 Problems.
5. Graph-Based Detection: Algorithms and Applications.
5.1 Introduction.
5.2 Factor Graphs and the Sum-Product Algorithm.
5.3 Finite-Memory Graph-Based Detection.
5.4 Complexity Reduction for Graph-Based Detection Algorithms.
5.5 Strictly Finite Memory: Inter-Symbol Interference Channels.
5.6 Applications to Wireless Communications
5.7 An Alternative Approach to Graph-Based Detection in the Presence of Strong Phase Noise.
5.8 Summary.
5.9 Problems.
Appendix: Discretization by Sampling.
A.1 Introduction.
A.2 Continuous-Time Signal Model.
A.3 Discrete-Time Signal Model.
References.
List of Acronyms.
Index.
发表于 2009-5-15 12:52:53 | 显示全部楼层
怎么没有附件?
发表于 2009-11-28 11:38:55 | 显示全部楼层
没有附件!
发表于 2009-11-29 11:58:05 | 显示全部楼层
谢谢。。。。。。
发表于 2009-12-15 11:43:47 | 显示全部楼层
没有附件
发表于 2009-12-15 14:17:57 | 显示全部楼层
没有附件?虚惊一场
发表于 2009-12-24 10:26:25 | 显示全部楼层
找到了 谢谢啊
发表于 2009-12-24 19:17:36 | 显示全部楼层
?? 哪里呢
发表于 2010-1-11 10:56:36 | 显示全部楼层
呵呵 在哪了
发表于 2010-3-27 14:57:04 | 显示全部楼层
附件呢?
GMT+8, 2025-12-19 06:26 , Processed in 0.020759 second(s), 6 queries , Gzip On, Redis On.
