查看: 3579|回复: 4
【Now 2008】Set Partition Coding Part I,Part II
发表于 2009-5-13 10:37:08 | 显示全部楼层 |阅读模式
题名:Set Partition Coding: Part I of Set Partition Coding and Image Wavelet Coding Systems
作者:William A. Pearlman1 and Amir Said
长度:86页,2008年,Now Publisher Inc.
题名:Image Wavelet Coding Systems: Part II of Set Partition Coding and Image Wavelet Coding Systems
长度:66页,2008年,Now Publisher Inc.
内容描述:Abstract
     This monograph describes current-day wavelet transform image codingsystems. As in the first part, steps of the algorithms are explained
thoroughly and set apart. An image coding system consists of several stages: transformation, quantization, set partition or adaptive entropy
coding or both, decoding including rate control, inverse transformation, de-quantization, and optional processing (see Figure 1.6). Wavelet
transform systems can provide many desirable properties besides high efficiency, such as scalability in quality, scalability in resolution, and
region-of-interest access to the coded bitstream. These properties are built into the JPEG2000 standard, so its coding will be fully described.
Since JPEG2000 codes subblocks of subbands, other methods, such as SBHP (Subband Block Hierarchical Partitioning) [3] and EZBC
(Embedded Zero Block Coder) [8], that code subbands or its subblocks independently are also described. The emphasis in this part is the use
of the basic algorithms presented in the previous part in ways that achieve these desirable bitstream properties. In this vein, we describe
a modification of the tree-based coding in SPIHT (Set Partitioning In Hierarchical Trees) [15], whose output bitstream can be decoded
partially corresponding to a designated region of interest and is simultaneously quality and resolution scalable. This monograph is extracted and adapted from the forthcoming textbook entitled Digital Signal Compression: Principles and Practice by William A. Pearlman and Amir Said, Cambridge University Press,
2009.
Set Partition Coding Part I of Set Partition Coding and Image Wavelet Coding Systems.pdf
872.41 KB, 下载次数: 24 , 下载积分: 资产 -2 信元, 下载支出 2 信元
abbr_7742f1b092fe0efe81b7c96ddb7eca5b.pdf
1.19 MB, 下载次数: 19 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-5-13 21:42:52 | 显示全部楼层
PART iI是哪个啊
 楼主| 发表于 2009-5-13 21:57:49 | 显示全部楼层
第一个附件是part I,第二个附件是part II,原标题太长,上传后系统自动重新编了题名。
发表于 2010-4-3 16:27:01 | 显示全部楼层
好书,推荐!!!
发表于 2011-4-7 07:03:08 | 显示全部楼层
顶一下楼主
GMT+8, 2025-12-26 05:33 , Processed in 0.018423 second(s), 8 queries , Gzip On, Redis On.
