查看: 18677|回复: 59
Design of high performance CMOS voltage-controlled oscillators
发表于 2009-5-12 22:21:59 | 显示全部楼层 |阅读模式
Design of high performance CMOS voltage-controlled oscillators 作者:Liang Dai, Ramesh Harjani
Voltage-controlled oscillators (VCOs) with low phase noise are the most critical building block in high performance phase-locked loops (PLL). Design of High-Performance CMOS Voltage-Controlled Oscillators presents a phase noise modeling framework for CMOS ring oscillators. The analysis considers both linear and nonlinear operation. It indicates that fast rail-to-rail switching has to be achieved to minimize phase noise. Additionally, in conventional design the flicker noise in the bias circuit can potentially dominate the phase noise at low offset frequencies. Therefore, for narrow bandwidth PLLs, noise up conversion for the bias circuits should be minimized. We define the effective Q factor (Qeff) for ring oscillators and predict its increase for CMOS processes with smaller feature sizes. Our phase noise analysis is validated via simulation and measurement results.
The digital switching noise coupled through the power supply and substrate is usually the dominant source of clock jitter. Improving the supply and substrate noise immunity of a PLL is a challenging job in hostile environments such as a microprocessor chip where millions of digital gates are present. Design of High-Performance CMOS Voltage-Controlled Oscillators noise, analyzes the impact of the supply and substrate noise on the oscillator phase noise, and suggests techniques for reducing the jitter due to the supply and substrate noise.
The primary audience for Design of High-Performance CMOS Voltage-Controlled Oscillators is research workers and design engineers who concentrate on high performance communication circuits. This work will also be of interest to analog circuit designers.
更多详细信息Design of high performance CMOS voltage-controlled oscillators
Edition: illustrated
由Springer出版, 2002
ISBN 1402072384, 9781402072383
158 页
[ 本帖最后由 meidinlei 于 2009-5-13 21:06 编辑 ]
 楼主| 发表于 2009-5-12 22:26:50 | 显示全部楼层
发表于 2009-5-12 22:29:36 | 显示全部楼层
 楼主| 发表于 2009-5-12 23:05:19 | 显示全部楼层
benemale 兄能找到这本书么?
google上只有预览
 楼主| 发表于 2009-5-12 23:09:33 | 显示全部楼层
居然在china-pub上发现原版书,开价
市场价 :¥1,981.04
普通会员 : ¥1,981.04
1-3星会员: ¥1,941.42
4-5星会员: ¥1,881.99
校园优惠价 : ¥1,881.99
发表于 2009-5-13 00:16:37 | 显示全部楼层
可以用这个软件试一下,最好把Microsoft .NET Framework 升级到最新版
Google图书下载.zip
1.58 MB, 下载次数: 169 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-5-13 20:59:22 | 显示全部楼层
这个软件可以下载google所有图书?
 楼主| 发表于 2009-5-13 21:06:10 | 显示全部楼层
可以参考作者的博士论文
http://www.eetop.cn/bbs/viewthread.php?tid=69158&highlight=Design%2Bof%2Bhigh-performance%2BVCOs
Design of high-performance VCOs for communications
发表于 2009-5-14 02:26:17 | 显示全部楼层
goooooooooood
发表于 2009-8-13 13:15:50 | 显示全部楼层
97
hao 书
在哪里弄到的?
GMT+8, 2025-12-26 04:35 , Processed in 0.027649 second(s), 6 queries , Gzip On, Redis On.
