查看: 29219|回复: 99
Tutorials on ADCs and DACs By Walt Kester Analog Devices 2006
发表于 2009-5-2 22:48:41 | 显示全部楼层 |阅读模式
Tutorials on ADC’s and DAC’s
By
Table of Contents
1
MT-001: Taking the Mystery out of the Infamous Formula,
"SNR=6.02N + 1.76dB," and Why You Should Care
6
1.1
INTRODUCTION
6
1.2
DERIVATION
6
1.3
CORRELATION BETWEEN QUANTIZATION NOISE AND INPUT SIGNAL YIELDS MISLEADING RESULTS
11
1.4
THEORETICAL NOISE FLOOR OF THE FFT OUTPUT
12
1.5
REFERENCES
13
2
MT-002: What the Nyquist Criterion Means to Your Sampled Data System Design
14
2.1
INTRODUCTION
14
2.2
THE NEED FOR A SAMPLE-AND-HOLD AMPLIFIER (SHA) FUNCTION
15
2.3
THE NYQUIST CRITERION
18
2.4
BASEBAND ANTIALIASING FILTERS
20
2.5
UNDERSAMPLING (HARMONIC SAMPLING, BANDPASS SAMPLING, IF SAMPLING, DIRECT IF-TO-DIGITAL CONVERSION)
23
2.6
ANTIALIASING FILTERS IN UNDERSAMPLING APPLICATIONS
24
2.7
SUMMARY
26
2.8
REFERENCES
26
3
MT-003: Understand SINAD, ENOB, SNR, THD, THD + N, and SFDR so You Don't Get Lost in the Noise Floor
26
3.1
INTRODUCTION
26
3.2
SIGNAL-TO-NOISE-AND-DISTORTION RATIO (SINAD), SIGNAL-TO-NOISE RATIO (SNR), AND EFFECTIVE NUMBER OF BITS (ENOB)
30
3.3
THE MATHEMATICAL RELATIONSHIPS BETWEEN SINAD, SNR, AND THD
32
3.4
SUMMARY
33
3.5
REFERENCES
33
4
MT-004: The Good, the Bad, and the Ugly Aspects of ADC Input Noise –Is No Noise Good Noise?
33
4.1
INTRODUCTION
34
4.2
INPUT-REFERRED NOISE (CODE TRANSITION NOISE)
34
4.3
NOISE-FREE (FLICKER-FREE) CODE RESOLUTION
36
4.4
INCREASING ADC "RESOLUTION" AND REDUCING NOISE BY DIGITAL AVERAGING
37
4.5
DON'T CONFUSE EFFECTIVE NUMBER OF BITS (ENOB) WITH "EFFECTIVE RESOLUTION" OR "NOISE-FREE CODE RESOLUTION"
38
4.6
USING NOISE DITHER TO INCREASE ADC SPURIOUS FREE DYNAMIC RANGE
38
4.7
SUMMARY
43
4.8
ACKNOWLEDGEMENTS
44
4.9
REFERENCES
44
5
MT-005: Noise Power Ratio (NPR) – A 65-Year Old Telephone System Specification Finds New Life in Modern Wireless Applications
44
5.1
INTRODUCTION
44
5.2
HISTORY OF NPR
45
5.3
SUMMARY
53
5.4
REFERENCES
54
5.5
APPENDIX
54
6
MT-006: ADC Noise Figure – An Often Misunderstood and Misinterpreted Specification
56
6.1
INTRODUCTION
57
6.2
ADC NOISE FIGURE DEFINITION
57
6.3
ADC NOISE FIGURE DERIVATION
58
6.4
EXAMPLE CALCULATION FOR AD9446 16-BIT 80/100-MSPS ADC
61
6.5
USING RF TRANSFORMERS TO DECREASE ADC NOISE FIGURE
62
6.6
CASCADED NOISE FIGURE
63
6.7
SUMMARY
65
6.8
REFERENCES
65
7
MT-007: Aperture Time, Aperture Jitter, Aperture Delay Time – Removing the Confusion
65
7.1
INTRODUCTION
66
7.2
EFFECT OF APERTURE JITTER AND SAMPLING CLOCK JITTER ON ADC SIGNAL-TO-NOISE RATIO (SNR)
68
7.3
MEASURING ADC APERTURE JITTER USING FFT TECHNIQUES
70
7.4
SUMMARY
72
7.5
REFERENCES
72
8.... MT-008: Converting Oscillator Phase Noise to Time Jitter
72
8.1
INTRODUCTION
73
8.2
PHASE NOISE DEFINED
73
8.3
CONVERTING PHASE NOISE TO JITTER
76
8.4
REFERENCES
82
9.... MT-009: Data Converter Codes–Can You Decode Them?
83
9.1
INTRODUCTION
83
9.2
UNIPOLAR CODES
86
9.3
GRAY CODE
89
9.4
BIPOLAR CODES
90
9.5
COMPLEMENTARY CODES
94
9.6
ACKNOWLEDGEMENT
94
9.7
REFERENCES
94
10
MT-010: The Importance of Data Converter Static Specifications –Don't Lose Sight of the Basics!
95
10.1
INTRODUCTION
95
10.2
DATA CONVERTER RESOLUTION AND QUANTIZATION
96
10.3
TRANSFER FUNCTIONS OF IDEAL DATA CONVERTERS
96
10.4
DATA CONVERTER GAIN AND OFFSET ERRORS
98
10.5
DATA CONVERTER LINEARITY ERRORS
99
11.. MT-011: Find Those Elusive ADC Sparkle Codes and Metastable States
105
11.1
INTRODUCTION
106
11.2
SPARKLE CODES, ERROR CODES, RABBITS, OR FLYERS
106
11.3
SPARKLE CODES IN FLASH CONVERTERS
107
11.4
SUMMARY
114
11.5
REFERENCES
114
12.. MT-012: Intermodulation Distortion Considerations for ADCs
115
12.1
INTRODUCTION
115
12.2
TWO TONE INTERMODULATION DISTORTION (IMD)
115
12.3
SECOND AND THIRD-ORDER INTERCEPT POINTS (IP2, IP3), 1-dB COMPRESSION POINT
116
12.4
MULTI-TONE SPURIOUS FREE DYAMIC RANGE
119
12.5
SUMMARY
120
12.6
REFERENCES
121
13.. MT-020: ADC Architectures I: The Flash Converter
121
13.1
INTRODUCTION
121
13.2
THE COMPARATOR: A 1-BIT ADC
121
13.3
FLASH CONVERTERS
125
13.4
Figure 4: 3-bit All-Parallel (Flash) Converter
126
13.5
TYPICAL FLASH CONVERTER TIMING
127
13.6
SUMMARY
136
13.7
REFERENCES
137
14.. MT-021: ADC Architectures II: Successive Approximation ADCs
138
14.1
INTRODUCTION
139
14.2
SAR ADC TIMING
140
14.3
ANALOG DEVICES ENTERS THE DATA CONVERTER ARENA IN 1969
145
14.4
Figure 6: ADC-12U 12-Bit, 10-µs SAR ADC from Pastoriza Division of Analog Devices, 1969
146
14.5
MODERN SAR ADCs
148
14.6
PROCESSING INDUSTRIAL-LEVEL SIGNALS
149
14.7
SUMMARY
151
14.8
REFERENCES
151
15.. MT-022: ADC Architectures III: Sigma-Delta ADC Basics
152
15.1
INTRODUCTION
153
15.2
HISTORICAL PERSPECTIVE
153
15.3
BASICS OF Σ-Δ ADCS
156
15.4
FREQUENCY DOMAIN ANALYSIS OF A SIGMA-DELTA ADC AND NOISE SHAPING
160
15.5
SUMMARY
164
15.6
REFERENCES
164
16.. MT-023: ADC Architectures IV: Sigma-Delta ADC Advanced Concepts and Applications
166
16.1
INTRODUCTION
167
16.2
IDLE TONE CONSIDERATIONS
167
16.3
HIGHER ORDER LOOP CONSIDERATIONS
169
16.4
MULTI-BIT SIGMA-DELTA CONVERTERS
169
16.5
DIGITAL FILTER IMPLICATIONS ON MULTIPLEXED APPLICATIONS
172
16.6
MULTISTAGE NOISE SHAPING (MASH) SIGMA-DELTA CONVERTERS
173
16.7
HIGH RESOLUTION MEASUREMENT SIGMA-DELTA ADCS
174
16.8
BANDPASS SIGMA-DELTA CONVERTERS
176
16.9
SUMMARY
177
16.10
REFERENCES
177
17.. MT-024: ADC Architectures V: Pipelined Subranging ADCs
178
17.1
INTRODUCTION
178
17.2
BASIC SUBRANGING ADC ARCHITECTURE
179
17.3
SUBRANGING ADCs WITH DIGITAL ERROR CORRECTION
182
17.4
Figure 6: A 6-Bit Subranging Error Corrected ADC, N1 = 3, N2 = 4
184
17.5
PIPELINED SUBRANGING ADCs INCREASE SPEED
187
17.6
RECIRCULATING SUBRANGING PIPELINED ADC
190
17.7
MODERN MONOLITHIC PIPELINED ADCs FOR VIDEO AND IMAGE PROCESSING
191
17.8
PIPELINED ADCs FOR WIDEBAND COMMUNICATIONS
191
17.9
THE LATEST IN PIPELINED ADCs
193
17.10
SUMMARY
193
17.11
REFERENCES
194
18.. MT-025: ADC Architectures VI: Folding ADCs
195
18.1
INTRODUCTION
195
18.2
BINARY AND FOLDING BIT-PER-STAGE (SERIAL) ADCs
196
18.3
SUMMARY
206
18.4
REFERENCES
206
19.. MT-026: ADC Architectures VII: Counting ADCs
208
19.1
INTRODUCTION
208
19.2
A. H. REEVES' 5-BIT COUNTING ADC
208
19.3
CHARGE RUN-DOWN ADC
209
19.4
RAMP RUN-UP ADC
210
19.5
TRACKING ADC
211
19.6
REFERENCES
213
20.. MT-027: ADC Architectures VIII: Integrating ADCs
214
20.1
INTRODUCTION
214
20.2
MULTI-SLOPE ADCs
214
20.3
REFERENCES
216
21.. MT-029: Optical Encoders
218
22
MT-031: Grounding Data Converters and Solving the Mystery of "AGND" and "DGND"
220
22.1
INTRODUCTION
220
22.2
GROUND AND POWER PLANES
221
22.3
LOW AND HIGH FREQUENCY DECOUPLING
222
22.4
DOUBLE-SIDED VS. MULTILAYER PRINTED CIRCUIT BOARDS
223
22.5
MULTICARD MIXED-SIGNALS SYSTEMS
224
22.6
SEPARATING ANALOG AND DIGITAL GROUND PLANES
225
22.7
GROUNDING AND DECOUPLING MIXED-SIGNAL ICs WITH LOW DIGITAL CURRENTS
226
22.8
TREAT THE ADC DIGITAL OUTPUTS WITH CARE
228
22.9
SAMPLING CLOCK CONSIDERATIONS
230
22.10
THE ORIGINS OF THE CONFUSION ABOUT MIXED-SIGNAL GROUNDING: APPLYING SINGLE-CARD GROUNDING CONCEPTS TO MULTICARD SYSTEMS
231
22.11
SUMMARY:
GROUNDING MIXED SIGNAL DEVICES WITH LOW DIGITAL CURRENTS IN A MULTICARD SYSTEM
232
22.12
SUMMARY:
GROUNDING MIXED SIGNAL DEVICES WITH HIGH DIGITAL CURRENTS IN A MULTICARD SYSTEM (USE THIS METHOD WITH CAUTION!)
234
22.13
GROUNDING SUMMARY
235
22.14
SOME GENERAL PC BOARD LAYOUT GUIDELINES FOR MIXED-SIGNAL SYSTEMS
235
22.15
REFERENCES
237
Tutorials on ADC-DAC-WaltKester.rar
3.31 MB, 下载次数: 1478 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-5-2 23:01:16 | 显示全部楼层
顶啊。。。。。顶啊。。。。。。好东西。。。。。指导性的。谢谢楼主
发表于 2009-5-2 23:09:01 | 显示全部楼层
:Q 感觉像骗子,付了5信元还是没有下载到。。。。鄙视之
发表于 2009-5-2 23:18:52 | 显示全部楼层
dingdingding
 楼主| 发表于 2009-5-2 23:30:49 | 显示全部楼层
发表于 2009-5-3 10:17:19 | 显示全部楼层
看看卡看,这么好的东东
发表于 2009-5-3 12:17:13 | 显示全部楼层
評價兩極~~
下載來研究一下
感恩ㄟ!!
发表于 2009-5-3 13:14:53 | 显示全部楼层
thank you!
发表于 2009-5-3 13:20:41 | 显示全部楼层
thank you
发表于 2009-5-3 13:31:33 | 显示全部楼层
怎么没有DAC的?
GMT+8, 2025-12-25 16:42 , Processed in 0.050640 second(s), 8 queries , Gzip On, Redis On.
