查看: 4705|回复: 6
IEEE文章Wide-band CMOS Low Noise Amplifier for Applications in Radio Astronomy
发表于 2009-4-30 18:45:28 | 显示全部楼层 |阅读模式
IEEE文章-----《Wide-band CMOS Low Noise Amplifier for Applications in Radio Astronomy》
作者------Leonid Belostotski*, Student Member, IEEE, James W. Haslett*, Fellow, IEEE, and Bruce Veidtt
Abstract
A CMOS low noise amplifier (LNA) is proposed for a proof-of-concept design of the Square Kilometer Array (SKA) radio telescope. A novel variation on
a well-known source-degenerated LNA topology is introduced that allows tuning of the power match centre frequency independently from the frequency
at which the LNAs noise figure approaches its minimum noise.The 0.7 - 1.4 GHz LNA designed in 0.18,um CMOS achieves better than 11 dB return loss
with a noise temperature of 40 K,provides a power gain of 17dB and IP1dB of -10dBm while consuming 50mW of power from a 1.8 V supply. The design
procedure of the LNA is presented and performance of the LNA is compared with previously published results.
Wide-band CMOS Low Noise Amplifier for.pdf
1.45 MB, 下载次数: 84 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-5-9 21:17:53 | 显示全部楼层
谢谢上传
发表于 2009-6-18 14:54:49 | 显示全部楼层
感谢楼主共享
发表于 2009-12-3 18:28:49 | 显示全部楼层
Thank you very much.
发表于 2009-12-3 19:14:25 | 显示全部楼层
Thanks for your sharing!
发表于 2013-7-25 06:01:08 | 显示全部楼层
大主題來了解......
发表于 2016-5-22 14:36:33 | 显示全部楼层
THANK YOU
GMT+8, 2025-12-25 09:22 , Processed in 0.020590 second(s), 10 queries , Gzip On, Redis On.
