查看: 10870|回复: 4
[原创] 请问Error: Project too complex: hierarchy path is too long怎么解决
发表于 2009-4-23 11:50:58 | 显示全部楼层 |阅读模式
Error: Entity "altsyncram_t072" is instantiated by entity "altsyncram"
Error: Entity "altsyncram" is instantiated by entity "cpu_ociram_lpm_dram_bdp_component_module"
Error: Entity "cpu_ociram_lpm_dram_bdp_component_module" is instantiated by entity "cpu_nios2_ocimem"
Error: Entity "cpu_nios2_ocimem" is instantiated by entity "cpu_nios2_oci"
Error: Entity "cpu_nios2_oci" is instantiated by entity "cpu"
Error: Entity "cpu" is instantiated by entity "nios32"
Error: Entity "nios32" is instantiated by entity "sdram"
Error: Entity "sdram" is instantiated by entity "nios32"
发表于 2010-3-10 22:48:19 | 显示全部楼层
你好,请问你这个问题是怎么解决的,我也遇到同样的问题了
发表于 2010-6-26 08:52:10 | 显示全部楼层
我也遇到了,怎么解决的啊?
发表于 2011-3-24 16:20:25 | 显示全部楼层
这是由于名字引起的, 在你创建nios32中是不是有命名sdram,外部的工程名也命名为sdram,如此重复引用(软件比较笨,就会按名字标记)就照成了层次路径太长,解决办法是 把其中同名的改个名字。
  在nios中修改了sdram的名字后,别忘了重新编译生成nios核,再在quartus中编译
发表于 2011-3-24 16:33:45 | 显示全部楼层
回复 4# sky418974783
GMT+8, 2025-12-25 03:02 , Processed in 0.049921 second(s), 8 queries , Gzip On, Redis On.
