查看: 2478|回复: 0
请大家帮慢看一个linux下字符设备驱动程序的问题,读没问题,写不行,
发表于 2005-6-28 22:40:47 | 显示全部楼层 |阅读模式
驱动编译没有错误,初始化和read()都没有问题。
但是当我在应用程序中调用write()函数的时候,老是返回-1。应该是static int s3c2410_write(struct file * file,const char * buffer, size_t count, loff_t *ppos)根本就没有执行,狂不解!!
请教大牛们!!急死我了!
#include <linux/config.h>
#include <linux/module.h>
#include <linux/kernel.h>
#include <linux/init.h>
#include <asm/io.h>
#include <linux/miscdevice.h>
#include <linux/sched.h>
#include <linux/delay.h>
#include <linux/poll.h>
#include <linux/spinlock.h>
#include <linux/irq.h>
#include <asm/arch/irqs.h>
#include <asm/delay.h>
#include <asm/arch/S3C2410.h>
#include <asm/hardware.h>
#define DEVICE_NAME      "IIC"
#define IIC_MAJOR 233
#define IICBUFSIZE 20
static DECLARE_WAIT_QUEUE_HEAD(s3c2410_wait);
static char iic_Data[IICBUFSIZE];
static volatile int iic_DataCount;
          iic_DataCount=count;
       printk("WRITE\n");
       copy_from_user(iic_Data,buffer,count);
     return 0;
static int s3c2410_read(struct file * file, char * buffer, size_t count, loff_t *ppos)
     int i;
     printk("READ\n");
     for(i=0;i<count;i++)   iic_Data=i*2;
     copy_to_user(buffer,iic_Data,iic_DataCount);
          return count;
static struct file_operations s3c2410_fops =
     owner:      THIS_MODULE,
     read: s3c2410_read,
     write: s3c2410_write,
static devfs_handle_t devfs_handle;
static int __init s3c2410_init(void)
     int ret;
     ret = register_chrdev(IIC_MAJOR, DEVICE_NAME, &s3c2410_fops);
     if (ret < 0) {
      printk(DEVICE_NAME " can't register major number\n");
      return ret;
     devfs_handle = devfs_register(NULL, DEVICE_NAME, DEVFS_FL_DEFAULT,IIC_MAJOR, 0, S_IFCHR | S_IRUSR | S_IWUSR,&s3c2410_fops, NULL);
     return 0;
static void __exit s3c2410_exit(void)
     devfs_unregister(devfs_handle);
     unregister_chrdev(IIC_MAJOR, DEVICE_NAME);
module_init(s3c2410_init);
module_exit(s3c2410_exit);
GMT+8, 2025-11-17 20:31 , Processed in 0.714601 second(s), 7 queries , Gzip On, Redis On.
