查看: 7118|回复: 5
关于Trans仿真中的一个问题
发表于 2009-3-18 00:49:41 | 显示全部楼层 |阅读模式
我在做crystal oscillator trans仿真中,由于仿得时间比较长(6ms 左右),因此导致在服务器上看波形时特别慢(波形文件有几G ),请问哪位有好的解决方法吗?比如只取部分波形文件中的点来看的这种。。。
多谢了.
PS:(仿真精度应该是不能再往下调了)
发表于 2009-3-18 01:55:41 | 显示全部楼层
You can save data after 5ms... however, simulation accuracy can't be reduced too much otherwise your result is unblievable
 楼主| 发表于 2009-3-18 04:32:25 | 显示全部楼层
Thanks, this is the answer I looking for.
But  how to set this option in my simulator(spectreRF) is still a problem for me. Can you give anything more about this?
 楼主| 发表于 2009-3-18 04:52:04 | 显示全部楼层
ok, I have found this option in my simulator.
Anyway, thanks again.
回复 支持 0 反对 1
发表于 2009-3-18 09:27:18 | 显示全部楼层
好像通过calculator可以直接取波形的某一个时间区域来看,取的时间短点,速度就快咯
发表于 2011-5-12 15:57:32 | 显示全部楼层
studying
GMT+8, 2025-12-12 10:21 , Processed in 0.022958 second(s), 6 queries , Gzip On, Redis On.
