楼主: llwanghong
求linux modelsim 6 .5 se 的license ?高人请指教
发表于 2009-12-24 10:35:50 | 显示全部楼层
thanks
发表于 2009-12-24 11:50:19 | 显示全部楼层
Great to see this crack, thanks
发表于 2010-1-3 07:12:26 | 显示全部楼层
thanks
发表于 2010-1-3 21:48:40 | 显示全部楼层
modelsim 6.5d有人试过吗?
发表于 2010-1-9 09:36:29 | 显示全部楼层
原来生成lic的时候要用网卡地址啊,谢谢楼主啦
发表于 2010-1-10 01:26:52 | 显示全部楼层
发表于 2010-1-12 14:52:18 | 显示全部楼层
说明文件中:
try these:
install modelsim 6.4
download the keygen
create the folder c:\flexlm
run the MentorKG.exe, at command line write c:\...\mentorkg -hd -o license.dat
put the license.dat at flexlm folder
run the Licensing Wizard of modelsim and at "user tools" tab click at the edit environment variables,
in "add a new value" write c:\flexlm\license.dat for both LM_LICENSE_FILE and MGLS_LICENSE_FILE
the modelsim now runs full for all of your life
发表于 2010-1-27 11:13:09 | 显示全部楼层
ewerwer
发表于 2010-2-9 15:04:44 | 显示全部楼层
10# ephemerality 太好了,谢谢
发表于 2010-2-11 20:03:26 | 显示全部楼层
好的是要顶的!
GMT+8, 2025-12-18 20:26 , Processed in 0.017458 second(s), 3 queries , Gzip On, Redis On.
