查看: 18656|回复: 52
[转帖]Samsung S3C2410初始化代码(ARmPALaDiN@sohu.com)
发表于 2003-9-25 08:31:07 | 显示全部楼层 |阅读模式
注:
1)  CPU:   Samsung S3C2410x
    SDRAM: 64MB/Bank6
    Flash: 16MB/NAND or 16MB/Intel Strata NOR(bank0)
2)  写一个空的C_Entry()函数,然后在ADS1.2中编译后生成bin文件直接烧入Flash即可作为一个简单的初始化代码,完成s3c2410的初始化,后续调试代码可以直接下载到SDRAM中.(RAM_STARTADDRESS=0x30000000)
; NAME: 2410INIT.S ;
; DESC: S3C2410 EVB Startup Code ;
; AUTH: PALaDiN@nicesun.com ;
; REV: 1.0.1 ;
; DATE: MAY,2003 ;
GBLL IDE_TYPE
GBLL CPU_CLK_200
IDE_TYPE SETL {TRUE}     ;TRUE=ADS1.2
                         ;FALSE=SDT2.5
[ IDE_TYPE
    GET option.s
    GET memcfg.s
    GET 2410addr.s ;here GET means INCLUDE used in C language
    GET option.a
    GET memcfg.a
    GET 2410addr.a
re-defined constants
USERMODE EQU 0x10
FIQMODE EQU 0x11
IRQMODE EQU 0x12
SVCMODE EQU 0x13
ABORTMODE EQU 0x17
UNDEFMODE EQU 0x1b
MODEMASK EQU 0x1f ;This means System Mode.
NOINT EQU 0xc0 ;
;The location of stacks
FIQStack EQU _STACK_BASEADDRESS
IRQStack EQU FIQStack+0x1000
AbortStack EQU IRQStack+0x1000
UndefStack EQU AbortStack+0x400
SVCStack EQU UndefStack+0x400
UserStack EQU SVCStack+0x1000
MACRO
    $HandlerLabel HANDLER $HandleLabel
    ; HANDLER is macroname
    ; $HandlerLabel is special macro name
    ; $HandleLabel is a variable
$HandlerLabel
    sub sp,sp,#4 ;decrement sp(to store jump address); sp<----sp - 4, ARM Stack is Full_Decending
    stmfd sp!,{r0} USH the work register to stack(lr does not push because it return to original address)
    ldr r0,=$HandleLabel ;load the address of HandleXXX to r0
    ldr r0,[r0] ;load the contents(service routine start address) of HandleXX
    str r0,[sp,#4] ;store the contents(ISR) of HandleXXX to stack
    ldmfd sp!,{r0,pc} OP the work register and pc(jump to ISR)
MEND
IMPORT |Image$$RO$$Limit| ; End of ROM code (=start of ROM data)
IMPORT |Image$$RW$$Base| ; Base of RAM to initialise
IMPORT |Image$$ZI$$Base| ; Base and limit of area
IMPORT |Image$$ZI$$Limit| ; to zero initialise
AREA Init,CODE,READONLY
    CODE32
    ENTRY
b ResetHandler ;
b HandlerUndef ;handler for Undefined mode 0x4
b HandlerSWI ;handler for SWI interrupt 0x8
b HandlerPabort ;handler for PAbort 0xC
b HandlerDabort ;handler for DAbort 0x10
b . ;reserved 0x14
b HandlerIRQ ;handler for IRQ interrupt 0x18
b HandlerFIQ ;handler for FIQ interrupt 0x1C
HandlerFIQ HANDLER HandleFIQ
HandlerIRQ HANDLER HandleIRQ
HandlerUndef HANDLER HandleUndef
HandlerSWI HANDLER HandleSWI
HandlerDabort HANDLER HandleDabort
HandlerPabort HANDLER HandlePabort
; ENTRY
ResetHandler
;Initialize stacks
bl InitStacks
; Configure Crucial Peripherals
ldr r0,=WTCON ;watch dog disable @0x5300_0000
ldr r1,=0x0 ;= means 0x0 is 32bit contant
str r1,[r0] ;
ldr r0,=INTMSK ;
ldr r1,=0xffffffff ;all interrupt disable
str r1,[r0]
ldr r0,=INTSUBMSK
ldr r1,=0x7ff ;
str r1,[r0]
;To reduce PLL lock time, adjust the LOCKTIME register.
ldr r0,=LOCKTIME
ldr r1,=0xffffff
str r1,[r0]
;Configure MPLL
ldr r0,=MPLLCON
ldr r1,=((M_MDIV<<12)+(M_PDIV<<4)+M_SDIV) ;Fin=12MHz,Fout=100MHz
str r1,[r0]
; Configure MEMORY CONTROLLER
;Set memory control registers according to SMRDATA section
ldr r0,=SMRDATA
ldr r1,=BWSCON ;BWSCON Address
add r2, r0, #52 ;End address of SMRDATA
0
    ldr r3, [r0], #4 ; load r3 from r0, then r0=r0+4
    str r3, [r1], #4 ; store r3 to r1, then r1=r1+4
    cmp r2, r0
    bne %B0
; Clear SDRAM
ldr r0,=GPFCON
ldr r1,=0x55aa ;GPF[7:4]--output GPF[3:0]--EINT[3:0]
str r1,[r0]
ldr r0,=GPFUP
ldr r1,=0xff ;GPF up-pull resistors are disabled
str r1,[r0]
ldr r0,=GPFDAT
ldr r1,=0x0
str r1,[r0] ;
mov r1,#0
mov r2,#0
mov r3,#0
mov r4,#0
mov r5,#0
mov r6,#0
mov r7,#0
mov r8,#0
ldr r9,=0x3ff0000 ;Lower 32MB
ldr r0,=0x30010000 ;leave 64kb for code//=0x30000000
LOOP ;SDRAM clear
stmia r0!,{r1-r8} ;stack starts from 0x30000000,
subs r9,r9,#32 ;
bne LOOP
; Exception Vector Table Setup
EXCEPTION_VECTOR_TABLE_SETUP
LDR r0, =HandleReset ; Exception Vector Table Memory Loc.
LDR r1, =ExceptionHandlerTable ; Exception Handler Assign
MOV r2, #8 ; Number of Exception is 8
ExceptLoop
LDR r3, [r1], #4
STR r3, [r0], #4
SUBS r2, r2, #1
BNE ExceptLoop
;Copy and paste RW data/zero initialized data
ldr r0, =|Image$$RO$$Limit| ; Get pointer to ROM data
ldr r1, =|Image$$RW$$Base| ; and RAM copy
ldr r3, =|Image$$ZI$$Base| ; Zero init base => top of initialised data
cmp r0, r1 ; Check that they are different
beq %F2 ; F means forward
1
    cmp r1, r3 ; Copy init data
    ldrcc r2, [r0], #4 ;--> LDRCC r2, [r0] + ADD r0, r0, #4
    strcc r2, [r1], #4 ;--> STRCC r2, [r1] + ADD r1, r1, #4
    bcc %B1 ;B means backward
2
    ldr r1, =|Image$$ZI$$Limit| ; Top of zero init segment
    mov r2, #0
3
    cmp r3, r1 ; Zero init
    strcc r2, [r3], #4
    bcc %B3
; Now change to user mode and set up user mode stack.
MRS r0, cpsr
BIC r0, r0, #MODEMASK ;MODEMASK=0X1F
ORR r0, r0, #USERMODE|NOINT ;R
MSR cpsr_cxsf, r0
LDR sp, =UserStack
;Jump To C Routines
IMPORT C_Entry
bl C_Entry ;Don not use main() because ......
;bl .
;Initialize Stacks
;function initializing stacks
InitStacks
;Don not use DRAM,such as stmfd,ldmfd......
;SVCstack is initialized before
;Under toolkit ver 2.5, 'msr cpsr,r1' can be used instead of 'msr cpsr_cxsf,r1'
mrs r0,cpsr
bic r0,r0,#MODEMASK ;MODEMASK=0x1f
orr r1,r0,#UNDEFMODE|NOINT ;r1=0xDB
msr cpsr_cxsf,r1 ;UndefMode
ldr sp,=UndefStack
orr r1,r0,#ABORTMODE|NOINT
msr cpsr_cxsf,r1 ;AbortMode
ldr sp,=AbortStack
orr r1,r0,#IRQMODE|NOINT
msr cpsr_cxsf,r1 ;IRQMode
ldr sp,=IRQStack
orr r1,r0,#FIQMODE|NOINT
msr cpsr_cxsf,r1 ;FIQMode
ldr sp,=FIQStack
bic r0,r0,#MODEMASK|NOINT
orr r1,r0,#SVCMODE
msr cpsr_cxsf,r1 ;SVCMode
ldr sp,=SVCStack
;USER mode has not be initialized.
mov pc,lr ;&acute;&Oacute;&para;&Ntilde;&Otilde;&raquo;&sup3;&otilde;&Ecirc;&frac14;&raquo;&macr;&sup3;&Igrave;&ETH;ò&Ouml;&ETH;·&micro;&raquo;&Oslash;
;The LR register won not be valid if the current mode is not SVC mode.
;The following DATA section is used to init MEMORY CONTROLLER
LTORG
SMRDATA DATA
;in ADS1.2 help documents, there is the following discription about DATA directive:
;;;;The DATA directive is no longer needed. It is ignored by the assembler.;;;;;;;;;;;;;;
; Memory configuration should be optimized for best performance
; The following parameter is not optimized.
; Memory access cycle parameter strategy
; 1) The memory settings is safe parameters even at HCLK=75Mhz.
; 2) SDRAM refresh period is for HCLK=75Mhz.
DCD (0+(B1_BWSCON<<4)+(B2_BWSCON<<8)+(B3_BWSCON<<12)+(B4_BWSCON<<16)+(B5_BWSCON<<20)+(B6_BWSCON<<24)+(B7_BWSCON<<28))
;DCD ((B6_BWSCON<<24)+(B7_BWSCON<<28))
DCD ((B0_Tacs<<13)+(B0_Tcos<<11)+(B0_Tacc<<8)+(B0_Tcoh<<6)+(B0_Tah<<4)+(B0_Tacp<<2)+(B0_PMC)) ;GCS0
DCD ((B1_Tacs<<13)+(B1_Tcos<<11)+(B1_Tacc<<8)+(B1_Tcoh<<6)+(B1_Tah<<4)+(B1_Tacp<<2)+(B1_PMC)) ;GCS1
DCD ((B2_Tacs<<13)+(B2_Tcos<<11)+(B2_Tacc<<8)+(B2_Tcoh<<6)+(B2_Tah<<4)+(B2_Tacp<<2)+(B2_PMC)) ;GCS2
DCD ((B3_Tacs<<13)+(B3_Tcos<<11)+(B3_Tacc<<8)+(B3_Tcoh<<6)+(B3_Tah<<4)+(B3_Tacp<<2)+(B3_PMC)) ;GCS3
DCD ((B4_Tacs<<13)+(B4_Tcos<<11)+(B4_Tacc<<8)+(B4_Tcoh<<6)+(B4_Tah<<4)+(B4_Tacp<<2)+(B4_PMC)) ;GCS4
DCD ((B5_Tacs<<13)+(B5_Tcos<<11)+(B5_Tacc<<8)+(B5_Tcoh<<6)+(B5_Tah<<4)+(B5_Tacp<<2)+(B5_PMC)) ;GCS5
DCD ((B6_MT<<15)+(B6_Trcd<<2)+(B6_SCAN)) ;GCS6
DCD ((B7_MT<<15)+(B7_Trcd<<2)+(B7_SCAN)) ;GCS7
DCD ((REFEN<<23)+(TREFMD<<22)+(Trp<<20)+(Trc<<18)+REFCNT)
DCD (0x31|0x80) ;SCLK power saving mode, BANKSIZE 64M/64M, 4-burst
DCD 0x30 ;MRSR6 CL=3clk
DCD 0x20 ;MRSR7
; Exception Vector Function Definition
; Consist of function Call from C-Program.
SystemResetHandler
b ResetHandler
SystemUndefinedHandler
IMPORT ISR_UndefHandler
STMFD sp!, {r0-r12,lr}
B ISR_UndefHandler
LDMFD sp!, {r0-r12, pc}^
SystemSwiHandler
LDR r0, [lr, #-4]
BIC r0, r0, #0xff000000
CMP r0, #0xff
BEQ MakeSVC
MakeSVC
MRS r1, spsr
BIC r1, r1, #MODEMASK
ORR r2, r1, #SVCMODE
MSR spsr_cf, r2
SystemPrefetchHandler
IMPORT ISR_PrefetchHandler
STMFD sp!, {r0-r12, lr}
B ISR_PrefetchHandler
LDMFD sp!, {r0-r12, lr}
SUBS pc, lr, #4
SystemAbortHandler
IMPORT ISR_AbortHandler
B ISR_AbortHandler
SUBS pc, lr, #8
SystemReserv
SUBS pc, lr, #4
SystemIrqHandler
IMPORT ISR_IrqHandler
BL ISR_IrqHandler
SUBS pc, lr, #4
SystemFiqHandler
IMPORT ISR_FiqHandler
STMFD sp!, {r0-r7, lr}
BL ISR_FiqHandler
LDMFD sp!, {r0-r7, lr}
SUBS pc, lr, #4
ALIGN
AREA RomData, DATA, READONLY
DCD SystemResetHandler
DCD SystemUndefinedHandler
DCD SystemSwiHandler
DCD SystemPrefetchHandler
DCD SystemAbortHandler
DCD SystemReserv
DCD SystemIrqHandler
DCD SystemFiqHandler
AREA RamData, DATA, READWRITE
^ _ISR_STARTADDRESS
HandleReset # 4
HandleUndef # 4
HandleSWI # 4
HandlePabort # 4
HandleDabort # 4
HandleReserved # 4
HandleIRQ # 4
HandleFIQ # 4
;Don not use the label 'IntVectorTable',
;The value of IntVectorTable is different with the address you think it may be.
;IntVectorTable
HandleEINT0 # 4
HandleEINT1 # 4
HandleEINT2 # 4
HandleEINT3 # 4
HandleEINT4_7 # 4
HandleEINT8_23 # 4
HandleRSV6 # 4
HandleBATFLT # 4
HandleTICK # 4
HandleWDT # 4
HandleTIMER0 # 4
HandleTIMER1 # 4
HandleTIMER2 # 4
HandleTIMER3 # 4
HandleTIMER4 # 4
HandleUART2 # 4
HandleLCD # 4
HandleDMA0 # 4
HandleDMA1 # 4
HandleDMA2 # 4
HandleDMA3 # 4
HandleMMC # 4
HandleSPI0 # 4
HandleUART1 # 4
HandleRSV24 # 4
HandleUSBD # 4
HandleUSBH # 4
HandleIIC # 4
HandleUART0 # 4
HandleSPI1 # 4
HandleRTC # 4
HandleADC # 4
END
发表于 2003-10-17 20:57:28 | 显示全部楼层
能否对这些代码加上注释啊,看不懂是怎么回事!
发表于 2004-4-1 16:57:30 | 显示全部楼层
是的,能否加上注释呢?这样就可以更加明白了啊!
发表于 2004-7-11 17:06:28 | 显示全部楼层
加上密码就好了  那样容易理解些
发表于 2004-12-15 23:48:07 | 显示全部楼层
非常感谢这样的free资料。
发表于 2005-2-8 15:35:55 | 显示全部楼层
thank you
发表于 2005-3-9 08:41:27 | 显示全部楼层
好呀,看来我是找对地方了,呵呵!
发表于 2005-4-4 12:31:37 | 显示全部楼层
谢谢!
发表于 2005-4-20 15:10:39 | 显示全部楼层
gloomy      长得怎么跟我一样?兄台是哪里人呀?在做什么ARM,有联系方法可以交流一下。我们要做ARM2410了
发表于 2005-4-30 14:25:51 | 显示全部楼层
很好的东西,可惜没有注释
GMT+8, 2025-12-29 15:24 , Processed in 0.027168 second(s), 10 queries , Gzip On, Redis On.
