楼主: 大龄青年
ldv 和ius是啥关系?
 楼主| 发表于 2009-3-14 13:46:23 | 显示全部楼层
还没搞懂
发表于 2009-3-23 01:11:43 | 显示全部楼层
IUS整合出一个平台,功能比LDV的仿真大多了
发表于 2009-6-11 11:21:59 | 显示全部楼层
同意。。。。。。。。。。。。。。。。。。。。。。。
发表于 2009-6-28 21:25:48 | 显示全部楼层
那位大侠知道哪能下IUS
发表于 2010-6-23 17:16:19 | 显示全部楼层
gfwaesgdfads
发表于 2010-6-23 17:17:53 | 显示全部楼层
gfwaesgdfads
发表于 2010-6-23 17:53:20 | 显示全部楼层
gsdfsdas
发表于 2010-6-23 17:55:31 | 显示全部楼层
thank s very much
发表于 2010-6-23 18:05:33 | 显示全部楼层
thanks for sharing
发表于 2010-6-23 18:09:11 | 显示全部楼层
This option also selects the maximum delay value if the min:typ:max value appears in the
SDF file while annotating to Verilog or to VITAL unless an SDF-specific construct is used to
override it. For example, if you use -maxdelays on the command line, but specify MINIMUM
in an SDF command file (MTM_CONTROL = “MINIMUM”), in an SDF configuration file (MTM
= MINIMUM;), or in the $sdf_annotate task, the maximum values in the specify block will
be used, but the minimum values in the SDF file will be used.
GMT+8, 2025-12-24 17:39 , Processed in 0.021172 second(s), 3 queries , Gzip On, Redis On.
