查看: 8533|回复: 23
Cuk关于状态空间平均的经典论文
发表于 2009-2-19 09:32:19 | 显示全部楼层 |阅读模式
Cuk和他的老师Dr.R. Middlebrook在70年代中期提出了了状态空间平均(State-Space Average)的方法,使得非线性开关转化电路的分析变成了可能。而该理论的提出使得我们可以从小信号的角度对开关系统进行建模。
这是两片系列论文,在IEEE上下载下来的,可以上IEEE的朋友可以自己去下载以节约点金币。
IEEE上的Abstract
A new concept in the design of switched-mode power conversion circuitry is presented. Because of its extreme simplicity, flexibility, and efficiency, it has the potential to replace some conventional electrical power processing methods currently in use. A thorough discussion of the background, development, and operation of the ¿uk converter and several of its extensions is included. The coupled-inductor technique further improves efficiency and reduces size and weight. The basic converter and its extensions to two-quadrant and four-quadrant operation are attractive for many applications, i.e., solar (dc) to utility line (ac) power conversion, variable speed dc or ac motor drives, switching power supplies, uninterruptible power supplies, and many others.
advances switched-mode power conversion PartI.pdf
4.4 MB, 下载次数: 181 , 下载积分: 资产 -3 信元, 下载支出 3 信元
advances switched-mode power conversion PartII.pdf
2.97 MB, 下载次数: 110 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-5-11 22:38:09 | 显示全部楼层
thanks~~
发表于 2009-5-15 13:21:17 | 显示全部楼层
真是非常的感谢阿
发表于 2009-5-15 14:30:04 | 显示全部楼层
非常的感谢阿
发表于 2009-8-25 13:24:46 | 显示全部楼层
good!!!!
发表于 2009-9-5 15:47:55 | 显示全部楼层
Thank you very much!!
发表于 2009-11-20 13:38:32 | 显示全部楼层
太好了,谢谢!!!!
发表于 2009-11-20 13:40:58 | 显示全部楼层
好了,再来一个
发表于 2009-12-14 14:24:32 | 显示全部楼层
Cuk和他的老师Dr.R. Middlebrook的这篇论文也很有名
A General Unified Approach to Modelling Switching-Converter Power Stages
发表于 2010-1-8 14:13:17 | 显示全部楼层
IEEE下不了,来这里下
GMT+8, 2025-12-25 13:26 , Processed in 0.031330 second(s), 6 queries , Gzip On, Redis On.
