楼主: ysliu168
Verilog-A from SmartSpice Training
发表于 2012-8-29 14:28:34 | 显示全部楼层
希望有用。谢谢。
发表于 2012-9-2 18:09:16 | 显示全部楼层
What Is SmartSpice Verilog-A?
- The SmartSpice Verilog-A is a high-level Analog Hardware Description Language (AHDL) that uses modules as the basic component to describe the structure and behavior of analog systems and their components
- With the analog statements of VERILOG-A, you can describe a wide range of conservative systems and signal-flow systems; such as electrical, mechanical, fluid dynamic, and thermodynamic systems
- To simulate systems that contain VERILOG-A components, you must have a VERILOG-A license and the SmartSpice simulator installed on your system
- To describe a system, specify both the structure of the system and the behavior of its components
- In VERILOG-A with the SmartSpice circuit simulator, the structures are defined at different levels
- At the highest level, you can define the overall system structure in a netlist
- At the lower, more specific levels, you can define the internal structure of modules by defining the interconnections among submodules
发表于 2012-10-10 16:30:35 | 显示全部楼层
- Training program-5
- 19 pages
发表于 2022-9-30 11:03:24 | 显示全部楼层
谢谢分享
GMT+8, 2025-12-22 02:35 , Processed in 0.018356 second(s), 3 queries , Gzip On, Redis On.
