查看: 11850|回复: 43
關於PLL設計與模擬電子書
发表于 2009-1-15 06:41:56 | 显示全部楼层 |阅读模式
Table of Contents
PLL BASICS ......................................................................................................................................................9
CHAPTER 1 BASIC PLL OVERVIEW ..................................................................................................................11
CHAPTER 2 THE CHARGE PUMP PLL WITH A PASSIVE LOOP FILTER............................................................15
CHAPTER 3 PHASE/FREQUENCY DETECTOR THEORETICAL OPERATION.......................................................17
CHAPTER 4 BASIC PRESCALER OPERATION .....................................................................................................25
CHAPTER 5 FUNDAMENTALS OF FRACTIONAL N PLLS ...................................................................................30
CHAPTER 6 DELTA SIGMA FRACTIONAL N PLLS ............................................................................................35
CHAPTER 7 THE PLL AS VIEWED FROM A SYSTEM LEVEL .............................................................................39
PLL PERFORMANCE AND SIMULATION................................................................................................45
CHAPTER 8 INTRODUCTION TO LOOP FILTER COEFFICIENTS.........................................................................47
CHAPTER 9 INTRODUCTION TO PLL TRANSFER FUNCTIONS AND NOTATION................................................52
CHAPTER 10 APPLICATIONS FOR PLL OTHER THAN A SIGNAL SOURCE........................................................58
CHAPTER 11 REFERENCE SPURS AND THEIR CAUSES ......................................................................................68
CHAPTER 12 FRACTIONAL SPURS AND THEIR CAUSES.....................................................................................81
CHAPTER 13 OTHER TYPES OF SPURS AND THEIR CAUSES.............................................................................96
CHAPTER 14 PLL PHASE NOISE MODELING AND BEHAVIOR........................................................................104
CHAPTER 15 INTEGRATED PHASE NOISE QUANTITIES...................................................................................116
CHAPTER 16 TRANSIENT RESPONSE OF PLL FREQUENCY SYNTHESIZERS ..................................................129
CHAPTER 17 IMPACT OF PFD DISCRETE SAMPLING EFFECTS ON LOCK TIME............................................142
CHAPTER 18 ROUTH STABILITY FOR PLL LOOP FILTERS ............................................................................152
CHAPTER 19 A SAMPLE PLL ANALYSIS.........................................................................................................157
PLL DESIGN .................................................................................................................................................171
CHAPTER 20 FUNDAMENTALS OF PLL PASSIVE LOOP FILTER DESIGN........................................................172
CHAPTER 21 EQUATIONS FOR A PASSIVE SECOND ORDER LOOP FILTER.....................................................177
CHAPTER 22 EQUATIONS FOR A PASSIVE THIRD ORDER LOOP FILTER........................................................181
CHAPTER 23 EQUATIONS FOR A PASSIVE FOURTH ORDER LOOP FILTER.....................................................189
CHAPTER 24 FUNDAMENTALS OF PLL ACTIVE LOOP FILTER DESIGN.........................................................199
CHAPTER 25 ACTIVE LOOP FILTER USING THE DIFFERENTIAL PHASE DETECTOR OUTPUTS ....................209
CHAPTER 26 IMPACT OF LOOP FILTER PARAMETERS AND FILTER ORDER ON REFERENCE SPURS............212
CHAPTER 27 OPTIMAL CHOICES FOR PHASE MARGIN AND GAMMA OPTIMIZATION PARAMETER ............220
CHAPTER 28 USING FASTLOCK AND CYCLE SLIP REDUCTION......................................................................228
CHAPTER 29 SWITCHED AND MULTIMODE LOOP FILTER DESIGN................................................................235
CHAPTER 30 DEALING WITH REAL-WORLD COMPONENTS...........................................................................239
CHAPTER 31 PARTIALLY INTEGRATED LOOP FILTERS..................................................................................243
ADDITIONAL TOPICS................................................................................................................................277
CHAPTER 32 LOCK DETECT CIRCUIT CONSTRUCTION AND ANALYSIS.........................................................279
CHAPTER 33 IMPEDANCE MATCHING ISSUES AND TECHNIQUES FOR PLLS .................................................286
CHAPTER 34 CRYSTAL OSCILLATORS AND VCOS .........................................................................................293
CHAPTER 35 OTHER PLL DESIGN AND PERFORMANCE ISSUES ....................................................................317
SUPPLEMENTAL INFORMATION...........................................................................................................325
CHAPTER 36 GLOSSARY AND ABBREVIATION LIST........................................................................................327
CHAPTER 37 REFERENCES..............................................................................................................................338
CHAPTER 38 USEFUL WEBSITES AND ONLINE RF TOOLS .............................................................................339
PLL.pdf
2.72 MB, 下载次数: 252 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-1-15 13:25:57 | 显示全部楼层
看看写得如何
发表于 2009-1-15 18:29:13 | 显示全部楼层
good!
发表于 2009-1-15 22:19:18 | 显示全部楼层
xiexie
发表于 2009-1-16 08:09:53 | 显示全部楼层
good!
发表于 2009-1-17 21:43:43 | 显示全部楼层
eetopeetop
发表于 2009-1-28 12:51:02 | 显示全部楼层
Thank you
发表于 2009-1-28 22:21:50 | 显示全部楼层
怎样才能不是负资产?
发表于 2009-1-28 22:23:49 | 显示全部楼层
可以下了!谢谢!
发表于 2009-1-28 23:04:26 | 显示全部楼层
看看写得如何
GMT+8, 2025-12-21 10:11 , Processed in 0.025911 second(s), 4 queries , Gzip On, Redis On.
