查看: 20908|回复: 59
lpc23xx/24xx--keil例子
发表于 2009-1-8 14:08:50 | 显示全部楼层 |阅读模式
common
    -- inc
-- lpc23xx.h  Definition file of all the registers of LPC23xx
    The LPC24xx register definition is also included.
-- irq.h  Interrupt related definitions and API prototyping
-- type.h  Type definition
-- target.h  Target specific definition for Keil's MCB2300 board
-- timer.h  Definition and header file for timer module
    -- src
-- startup.s  Code start up entry
-- swi_handler.s SWI handler
    Note: not used, but a good example for future references.
-- irq.c  Generic SWI interrupt handler related APIs
-- target.c  Target specific modules
-- timer.c  Timer related APIs
GPIO
    -- fio.h   GPIO and fast I/O header
    -- fio.c   GPIO and fast I/O APIs
    -- fiotest.c  GPIO and Fast I/O test module
    -- fio.uv2   uVision project file
EXTINT
    -- extint.h   External interrupt header
    -- extint.c   External interrupt APIs
    -- einttest.c  External interrupt test module
    -- extint.uv2  uVision project file
Timer
    -- tmrtest.c  Timer test module, note: API modules
    are in the COMMON directory and
    shared and used by some other peripheral testing.
    -- timer.uv2  uVision project file
PWM
    -- pwmc.h   PWM header
    -- pwm.c   PWM APIs
    -- pwmtest.c  PWM test module
    -- pwm.uv2   uVision project file
SPI
    -- spi.h   SPI header
    -- spi.c   SPI APIs
    -- spitest.c  SPI test module
    -- spi.uv2   uVision project file
SSP
    -- ssp.h   SSP(SPI1) header
    -- ssp.c   SSP(SPI1) APIs
    -- dma.h   SSP DMA header
    -- dma.c   SSP DMA APIs
    -- ssptest.c  SSP(SPI1) test module
    -- ssp.uv2   uVision project file
UART
    -- uart.h   UART header
    -- uart.c   UART APIs
    -- uarttest.c  UART test module
    -- uart.uv2   uVision project file
RTC
    -- rtc.h   Real-time clock(RTC) header
    -- rtc.c   Real-time clock(RTC) APIs
    -- rtctest.c  Real-time clock(RTC) test module
    -- rtc.uv2   uVision project file
MCI
    -- mci.h   MCI header
    -- mci.c   MCI APIs for both SD and MMC card interface
    -- dma.h   MCI DMA header
    -- dma.c   MCI DMA APIs.
    -- mcitest.c  MCI test module
    -- mci.uv2   uVision project file
ADC
    -- adc.h   ADC header
    -- adc.c   ADC APIs
    -- adctest.c  ADC controller test module
    -- adc.uv2   uVision project file
DAC
    -- dac.h   DAC header
    -- dac.c   DAC APIs
    -- dactest.c  DAC test module
    -- dac.uv2   uVision project file
I2C
    -- i2c.h   I2C header
    -- i2c.c   I2C APIs
    -- i2cmst.c   I2C test module
    -- i2cmst.uv2  uVision project file
I2S
    -- i2s.h   I2S header
    -- i2s.c   I2S APIs
    -- dma.c   I2S DMA APIs
    -- dma.h   I2S DMA header
    -- i2stest.c  I2S test module
    -- i2s.uv2   uVision project file
CAN
    -- can.h   CAN header
    -- can.c   CAN APIs
    -- cantest.c  CAN test module
    -- can.uv2   uVision project file
DMA
    -- dma.h   DMA header
    -- dma.c   GPDMA APIs, memory to memory only.
    Note: memory to peripheral or peripheral
    to memory are in SSP, MCI, and I2S directories.
    -- dmatest.c  DMA test module
    -- dma.uv2   uVision project file
WDT
    -- wdt.h   Watchdog timer header
    -- wdt.c   Watchdog timer APIs
    -- wdttest.c  Watchdog timer test module
    -- wdt.uv2   uVision project file
PWRMAN
    -- pwrman.h   Power management header
    -- pwrman.c   Power management APIs
    -- pmtest.c   Power management test module,
    test powerdown and external interrupt wakeup.
    -- pwrman.uv2  uVision project file
PortLCD
    -- portlcd.h  4-bit port to LCD driver header for Keil MCB2300
    -- portlcd.c  4-bit port to LCD driver APIs
    -- lcdtest.c  4-bit port to LCD test module
    -- portlcd.uv2  uVision project file
EMAC
    -- crc32.h   CRC calculation header
    -- crc32.c   CRC calculation APIs
    -- emac.h   EMAC header
    -- emac.c   EMAC APIs, options include transmit only(TX_ONLY);
    receive packet, switch source and destination
    and transmit(BOUNCE_RX), WOL, etc.
    -- emactest.c  EMAC test module
    -- emac.uv2   uVision project file
    -- ethpkt.txt  Ethernet packet example for transmit
USBDEV
    -- hid.h   USB HID related header
    -- hiduser.h  USB HID user specific header
    -- hiduser.c  USB HID user APIs
    -- usb.h   USB header
    -- usbcfg.h   USB configuration header
    -- usbcore.h  USB Core header
    -- usbcore.c  USB Core APIs
    -- usbdesc.h  USB descriptor header
    -- usbdesc.c  USB descriptor APIs
    -- usbhw.h   USB hardware header
    -- usbhw.c   USB hardware APIs
    -- usbreg.h   USB misc. register header
    -- usbuser.h  USB user header
    -- useuser.c  USB user APIs
    -- usbmain.c  USB HID test module, power management, USB
    suspend to powerdown, and resume to USB
    wakeup.
    -- usbdev.uv2  uVision project file
USBAudio
    -- audio.h   USB Audio related header
    -- adcuser.h  USB Audio Device Class user specific header
    -- adcuser.c  USB Audio Device Class user APIs
    -- usb.h   USB header
    -- usbaudio.h  USB Audio misc. definition header
    -- usbmain.c  USB Audio test module
    -- usbaudio.uv2  uVision project file
EXTMEM ( LPC24xx only, tested on Embedded Artists LPC24xx OEM board)
    -- NOR_Flash
-- ex_norflash.h NOR flash configuration header for Embedded Artists LPC2400
    OEM board
-- ex_norflash.c NOR flash configuration and access APIs
-- norflash_test.c NOR flash test module
-- ex_norflash.uv2 uVision project file
    -- NAND_Flash
-- ex_nandflash.h NAND flash configuration header for Embedded Artists LPC2400
    OEM board
-- ex_nandflash.c NAND flash configuration and access APIs
-- nandflash_test.c NAND flash test module
-- ex_nandflash.uv2 uVision project file
    -- SDRAM
-- ex_sdram.h  SDRAM configuration header for Embedded Artists LPC2400
    OEM board
-- ex_sdram.c  SDRAM configuration and access APIs
-- uart.h  UART debugging header file for stand-alone SDRAM test
-- uart.c  UART debugging file for stand-alone SDRAM test
-- sdram_test.c  SDRAM test module
-- ex_sdram.uv2  uVision project file
EA_LCD (Embedded Artists QVGA LCD controller OEM board )
    -- lcd_hw.h   16-bit port to LCD controller driver header for Embedded Artists
    LPC2400 OEM base board
    -- lcd_hw.c   16-bit port to LCD controller driver APIs
    -- lcd_grph.c  Graphic related APIs such as drawing an object such as a line,
    a circle, etc.
    -- lcd_grph.h  Header file to support lcd_graph.c
    -- font5x7.c  a 5x7 font for letters and numbers, etc.
    -- font5x7.h  font related header
    -- font_macro.h  font macro
    -- ealcd_test.c  16-bit port to LCD controller test module
    -- ea_lcd.uv2  uVision project file
USBHost
    -- usbhost.h  USB host header
    -- usbhost.c  USB host APIs
    -- hcdtest.c  USB host test module,
    USB host initialization only, no queue setup and enumeration yet.
    -- usbhost.uv2  uVision project file
USBUVC
    -- lpc2300.s  Startup file for USBUVC project.
    (This stand-alone project doesn't use any of the library files
    under the common directory.)
    -- uvc.h   USB Video related header
    -- uvcuser.h  USB Video Device Class user specific header
    -- uvcuser.c  USB Video Device Class user APIs
    -- usb.h   USB header
    -- usbuser.c  USB user APIs
    -- type.h   Local type definition header
    -- lcd.h   display support module header
    -- lcd.c   Display support module
    -- uvcdemo.c  USB UVC test module
    -- uvc.uv2   uVision project file
    -- debug.ini  Debug configuration setting
LPC23xx_24xxSampleSoftware.r5.rar
1.24 MB, 下载次数: 567 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-3-7 11:16:39 | 显示全部楼层
好东西要顶
发表于 2009-3-7 11:18:38 | 显示全部楼层
好东西要顶
发表于 2009-3-9 19:07:54 | 显示全部楼层
谢谢!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
发表于 2009-4-1 15:49:07 | 显示全部楼层
有用的东东
发表于 2009-4-11 18:34:32 | 显示全部楼层
eetopeetopeetopeetopeetopeetop
发表于 2009-4-17 12:29:16 | 显示全部楼层
haodongdong,xiexie
发表于 2009-6-4 08:55:53 | 显示全部楼层
want to have a look
发表于 2009-6-4 08:57:21 | 显示全部楼层
why I can't download?
发表于 2009-6-4 12:02:40 | 显示全部楼层
我也下来看看
GMT+8, 2025-12-15 18:34 , Processed in 0.025337 second(s), 6 queries , Gzip On, Redis On.
