楼主: milanlion
请教一个HSPICE做monte carlo 分析的问题
发表于 2010-8-22 13:19:58 | 显示全部楼层
对于Vth0,如果也想随机,可以在gate上串联一个 高斯分布的vth_shift
发表于 2010-12-29 22:08:42 | 显示全部楼层
monte
发表于 2011-6-7 03:16:23 | 显示全部楼层
这个TOPIC我喜欢,希望更多的人能参与讨论哈
发表于 2011-12-16 15:42:52 | 显示全部楼层
多谢楼主,学习了
发表于 2013-1-26 21:26:27 | 显示全部楼层
好东西啊
发表于 2014-1-3 14:40:49 | 显示全部楼层
感谢楼主,受教了~
发表于 2015-9-9 04:14:40 | 显示全部楼层
hi guys
thanks to eetop and its cool member i finally find standard tsmc 65nm hspice PDK
but my problem is i dont know how to do monte carlo analysis with it
the library name is "crn65lp_2d5_lk_v1d7.l" you can find it easlly in eetop
can any of you guys give me an example on it plz?
发表于 2015-9-25 15:27:51 | 显示全部楼层
LZ有解决吗?无论的Resistance还是MOS,如果将变量定义在了Model card中,做MC分析,每次仿真都是调用同一个数值,所以仿真出来的结果一样。
我也期待大牛解答。希望大家积极讨论。
发表于 2015-9-27 01:20:07 | 显示全部楼层
回复 1# milanlion
Hi, there
Re-ran your simulation using completely identical netlist copied 'n pasted from your thread directly with hspice version 2012.06-sp1
********Monte=1
      MODEL PARAMETER MONTE CARLO DEFINITIONS
           0           0
        0:r1
rsheet
     resistor        =   98.23
           0           0
        0:r2
rsheet
     resistor        =   99.77
           0           0
        0:r3
rsheet
     resistor        =   100.3
           0           0
        0:r4
rsheet
     resistor        =   98.24
four resistors
  ******  dc transfer curves tnom=  25.000 temp=  25.000 *****
       MONTE CARLO PARAMETER DEFINITIONS
rsheet
      bias      voltage      voltage      voltage      voltage
                     1            2            3            4
    1.00000m    982.3457m    997.6751m      1.0026     982.3688m
    1.10000m      1.0806       1.0974       1.1029       1.0806
    1.20000m      1.1788       1.1972       1.2031       1.1788
    1.30000m      1.2770       1.2970       1.3034       1.2771
    1.40000m      1.3753       1.3967       1.4036       1.3753
    1.50000m      1.4735       1.4965       1.5039       1.4736
    1.60000m      1.5718       1.5963       1.6042       1.5718
    1.70000m      1.6700       1.6960       1.7044       1.6700
    1.80000m      1.7682       1.7958       1.8047       1.7683
    1.90000m      1.8665       1.8956       1.9049       1.8665
    2.00000m      1.9647       1.9954       2.0052       1.9647
y
********Monte=2
   *** monte carlo  index =            1 ***
           0           0
        0:r1
rsheet
     resistor        =   98.23
           0           0
        0:r2
rsheet
     resistor        =   99.77
           0           0
        0:r3
rsheet
     resistor        =   100.3
           0           0
        0:r4
rsheet
     resistor        =   98.24
four resistors
rsheet
                     1            2            3            4
y
   *** monte carlo  index =            2 ***
           0           0
        0:r1
rsheet
     resistor        =   97.98
           0           0
        0:r2
rsheet
     resistor        =   101.9
           0           0
        0:r3
rsheet
     resistor        =   101.8
           0           0
        0:r4
rsheet
     resistor        =   98.24
rsheet
                     1            2            3            4
    1.00000m    979.7572m      1.0186       1.0184     982.4214m
    1.10000m      1.0777       1.1204       1.1202       1.0807
    1.20000m      1.1757       1.2223       1.2220       1.1789
    1.30000m      1.2737       1.3242       1.3239       1.2771
    1.40000m      1.3717       1.4260       1.4257       1.3754
    1.50000m      1.4696       1.5279       1.5276       1.4736
    1.60000m      1.5676       1.6297       1.6294       1.5719
    1.70000m      1.6656       1.7316       1.7312       1.6701
    1.80000m      1.7636       1.8335       1.8331       1.7684
    1.90000m      1.8615       1.9353       1.9349       1.8666
    2.00000m      1.9595       2.0372       2.0367       1.9648
y
Thanks
发表于 2015-12-20 22:14:32 | 显示全部楼层
这个帖子好  顶起来 希望大家继续讨论
GMT+8, 2025-12-26 07:40 , Processed in 0.019175 second(s), 5 queries , Gzip On, Redis On.
