查看: 3580|回复: 0
请教:PCI到cpu的地址映射问题!
发表于 2008-12-31 14:09:55 | 显示全部楼层 |阅读模式
下面是bsp包里的配置文件,谁能帮忙解释一下pci的空间是怎么映射到系统空间的?
谢谢!
#ifdef  INCLUDE_PCI
#define INCLUDE_PCI_AUTOCONF
CPU Addr     PCI Addr
PCI_LOCAL_MEM_BUS ------------------------- PCI_MSTR_MEM_BUS
PCI_LOCAL_MEM_BUS + ------------------------- PCI_MSTR_MEM_BUS +
PCI_LOCAL_MEM_SIZE ----IMMR               - PCI_MSTR_MEM_SIZE
          -          -----PIMMR
CPU_PCI_MEM_ADRS ------------------------- PCI_MEM_ADRS
CPU_PCI_MEMIO_ADRS ------------------------- PCI_MEMIO_ADRS
CPU_PCI_IO_ADRS  ------------------------- PCI_IO_ADRS
CPU_PCI_IO_ADRS + ------------------------- PCI_IO_ADRS +
CPU_PCI_IO_SIZE  -        - PCI_IO_SIZE
          -------------------------- 4GBytes
/* for custom sysPciAutoConfig.c */
/* PCI based addresses */
#define PCI_MEM_ADRS  0x50000000
#define PCI_MEM_SIZE  0x01000000   /*16MB */
#define PCI_MEM_SIZE_MASK PCI_SIZE_MASK_16M /* This should match PCI_MEM_SIZE */
#define PCI_MEMIO_ADRS  0x60000000
#define PCI_MEMIO_SIZE  0x01000000   /*16MB */
#define PCI_MEMIO_SIZE_MASK PCI_SIZE_MASK_16M /* This should match PCI_MEMIO_SIZE */
#define PCI_IO_ADRS 0x70000000
#define PCI_IO_SIZE 0x00100000 /* IO Space is not available */
/* CPU based addresses */
#define CPU_PCI_MEM_ADRS  0x80000000
#define CPU_PCI_MEM_SIZE  PCI_MEM_SIZE
#define CPU_PCI_MEMIO_ADRS  0x90000000
#define CPU_PCI_MEMIO_SIZE  PCI_MEMIO_SIZE
#define CPU_PCI_IO_ADRS   0xa0000000
#define CPU_PCI_IO_SIZE   PCI_IO_SIZE
/* CPU from PCI bus */
#define PCI_MSTR_MEM_BUS  0x00000000
#define PCI_MSTR_MEM_SIZE  PCI_LOCAL_MEM_SIZE
#define PCI_BRIDGE_PIMMR_BASE_ADRS      0x40000000
/* CPU Address that is visible from PCI */
#define PCI_LOCAL_MEM_BUS LOCAL_MEM_LOCAL_ADRS
#define PCI_LOCAL_MEM_SIZE LOCAL_MEM_SIZE
/* This should match LOCAL_MEM_SIZE - if not statically defined buffers
   need to be used for PCI devices */
#define PCI_MSTR_MEM_SIZE_MASK PCI_SIZE_MASK_64M
#ifndef PCI_CFG_TYPE
# ifdef INCLUDE_PCI_AUTOCONF
#  define PCI_CFG_TYPE PCI_CFG_AUTO
# else
#  define PCI_CFG_TYPE PCI_CFG_FORCE
# endif /* INCLUDE_PCI_AUTOCONF */
#endif /* PCI_CFG_TYPE */
#endif /* INCLUDE_PCI */
GMT+8, 2025-12-25 18:08 , Processed in 0.013413 second(s), 6 queries , Gzip On, Redis On.
