查看: 2798|回复: 1
请教高手一个有关C51指针的问题
发表于 2008-11-10 10:43:19 | 显示全部楼层 |阅读模式
在C51的说明文档里面,有这么这么两段:
Abstract pointer types are described here using code examples with the following variables.
char xdata *px;       /* ptr to xdata */char idata *pi;       /* ptr to idata */char code  *pc;       /* ptr to code  */”与:“Memory-specific pointers always include a memory type specification in the pointer declaration and always refer to a specific memory area. For example:
char data *str;        /* ptr to string in data */int xdata *numtab;     /* ptr to int(s) in xdata */long code *powtab;     /* ptr to long(s) in code */ ”我的问题是这两个的确切的区别是怎么理解的呢?谢谢各位指教!
 楼主| 发表于 2008-11-10 10:47:02 | 显示全部楼层
有点乱,再写一次
C51说明里有这么两段:
我的问题是这两段的确切区别是怎么理解的?谢谢各位的指教!
GMT+8, 2025-9-18 06:18 , Processed in 0.017286 second(s), 6 queries , Gzip On, Redis On.
