查看: 5762|回复: 33
【新】Signal Processing Requirements for WiMAX (802.16e) Base Station
发表于 2008-11-6 15:16:11 | 显示全部楼层 |阅读模式
Contents
ABSTRACT...........................................................................................................................IV
ACKNOWLEDGEMENTS...................................................................................................VI
CONTENTS........................................................................................................................VIII
LIST OF FIGURES................................................................................................................X
PART 0: INTRODUCTION....................................................................................................1
0.1 GOAL OF THE THESIS.........................................................................................................3
0.2 REPORT OUTLINE...............................................................................................................3
0.3 INTRODUCTION TO WIMAX..............................................................................................3
0.3.1 802.16c.................................................................................................................................3
0.3.2 802.16a.................................................................................................................................4
0.3.3 802.16d.................................................................................................................................4
0.3.4 802.16e.................................................................................................................................4
0.4 OFDM SYSTEM DESCRIPTION............................................................................................5
0.4.1 Effects of Receiver performance............................................................................................7
PART 1: CHANNEL ESTIMATION.....................................................................................9
1.1 INTRODUCTION..................................................................................................................9
1.2 UP LINK TRANSMISSION....................................................................................................9
1.3 THE BLOCK DIAGRAM.....................................................................................................10
1.3.1 Transmitter.........................................................................................................................11
1.3.2 Channel...............................................................................................................................12
1.3.3 Receiver..............................................................................................................................15
1.4 PROBLEM DESCRIPTION...................................................................................................17
1.5 SIMULATION RESULTS.....................................................................................................18
1.5.1 Performance in AWGN channel..........................................................................................18
1.5.2 Performance in a Rayleigh Fading Channel.......................................................................20
1.5.3 Effect of mobile speed..........................................................................................................23
1.5.4 Performance in presence of Multipath................................................................................24
1.5.5 Effect of multipath delay spread..........................................................................................28
1.5.6 Effect of Channel coding.....................................................................................................30
1.6 DISCUSSION.....................................................................................................................32
PART 2: RANGING..............................................................................................................34
2.1 INTRODUCTION................................................................................................................34
2.2 PROBLEM DESCRIPTION...................................................................................................35
2.3 TIMING OFFSET CALCULATION.........................................................................................35
2.3.1: Cross-correlation in time domain......................................................................................35
2.3.2: Auto-correlation in time domain........................................................................................36
2.3.3: Correlation in frequency domain.......................................................................................37
2.4 FREQUENCY AND POWER OFFSET CALCULATION.............................................................39
2.5 SIMULATION RESULTS.....................................................................................................39
2.6 PROCESSING LOAD CALCULATION...................................................................................42
PART 3: ANTENNA BEAMFORMING.............................................................................46
3.1 INTRODUCTION................................................................................................................46
3.2 BEAMFORMING BASICS....................................................................................................47
3.3 TYPES OF BEAMFORMING.................................................................................................48
3.4 PARAMETERS EFFECTING BEAMFORMING........................................................................50
3.5 ADAPTIVE ANTENNA SYSTEM FOR OFDMA IN 802.16E..................................................50
3.6 DIRECTION OF ARRIVAL COMPUTATION (DOA)...............................................................53
3.6.1 Capon’s method...................................................................................................................53
3.6.2 MUSIC algorithm................................................................................................................54
3.7 SIMULATION RESULTS.....................................................................................................54
3.8 CONCLUSION...................................................................................................................57
A. REFERENCES..................................................................................................................60
B. ACRONYMS......................................................................................................................62
Signal Processing Requirements for WiMAX (802.16e) Base Station.pdf
1.41 MB, 下载次数: 142 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-11-11 11:23:17 | 显示全部楼层
thanks
发表于 2008-11-11 11:44:07 | 显示全部楼层
好书!!!!!!!!!!!!
发表于 2008-11-12 11:48:12 | 显示全部楼层
谢谢分享
发表于 2008-11-12 12:29:01 | 显示全部楼层
谢谢分享。。。。。
发表于 2008-11-17 08:38:58 | 显示全部楼层
看内容还比较不错,谢谢先
发表于 2008-11-18 20:43:19 | 显示全部楼层
这种文章比较实用,谢谢楼主分享
发表于 2008-11-19 09:00:07 | 显示全部楼层
好东西,值得一看,谢谢楼主共享。
发表于 2008-11-19 11:39:56 | 显示全部楼层
如何撮合成交股票
联系人:叶经理   手机/电话:13761298860   QQ:1029153609   欢迎来电咨询开户转户事宜
    证券经营机构受理投资者的买卖委托后,应即刻将信息按时间先后顺序传送到交易所主机,公开申报竞价。股票申报竞价时,可依有关规定采用集合竞价或连续竞价方式进行,交易所的撮合大机将按“价格优先,时间优先”的原则自动撮合成交。
    目前,沪、深两家交易所均存在集合竞价和连续竞价方式。上午9:15--9:25为集合竞价时间,其余交易时间均为连续竞价时间。在集合竞价期间内,交易所的自动撮合系统只储存而不撮合,当申报竞价时间一结束,撮合系统将根据集合竞价原则,产生该
股票的当日开盘价。沪、深新股挂牌交易的第一天不受涨跌幅10%的限制,但深市新股上市当日集合竞价时,其委托竞价不能超过新股发行价的上下15元,否则,该竞价在集合竞价中作无效处理,只可参与随后的连续竞价。
    集合竞价结束后,就进入连续竞价时间,即9:30-11:30和13:00--15:00。投资者的买卖指令进入交易所主机后,撮合系统将按“价格优先,时间优先”的原则进行自动撮合,同一价位时,以时间先后顺序依次撮合。在撮合成交时,
股票成交价格的决定原则为:⒈成交价格的范围必须在昨收盘价的上下10%以内;⒉最高买入申报与最高卖出申报相同的价位;⒊如买(卖)方的申报价格高(低)于卖(买)方的申报价格时,采用双方申报价格的平均价位。交易所主机撮合成交的,主机将成交信息即刻回报到券商处,供投资者查询。未成交的或部分成交的,投资者有权撤消自己的委托或继续等待成交,一般委托有效期为一天。
    另外,深市股票的收盘价不是该股票当日的最后一笔的成交价,而是该
股票当日有成交的最后一分钟的成交金额除以成交量而得。
转载至:无忧开户
发表于 2008-11-19 16:57:30 | 显示全部楼层
收下看看。篇幅很短,希望不是介绍性的
GMT+8, 2025-10-19 17:26 , Processed in 0.027964 second(s), 6 queries , Gzip On, Redis On.
