查看: 12146|回复: 43
[原创] 【新】1.2GPS 32 to 2048 point Floating Point FFT in a single FPGA
发表于 2008-11-6 15:01:06 | 显示全部楼层 |阅读模式
Hybrid Floating Point Technique Yields 1.2 Gigasample Per Second 32 to 2048 point Floating Point FFT in a single FPGABy Raymond J. Andraka
Abstract:Hardware Digital Signal Processing, especially hardware targeted to FPGAs, has traditionally been done using fixed point arithmetic, mainly due to the high cost associated with implementing floating point arithmetic. That cost comes in the form of increased circuit complexity. The increase circuit complexity usually also degrades maximum clock performance. Certain applications demand the dynamic range offered by floating point hardware, and yet require the speeds and circuit density usually associated with fixed point hardware. The Fourier transform is one DSP building block that frequently requires floating point dynamic range. Textbook construction of a pipelined floating point FFT engine capable of continuous input entails dozens of floating point adders and multipliers. The complexity of those circuits quickly exceeds the resources available on a single FPGA. This paper describes a technique that is a hybrid of fixed point and floating point operations designed to significantly reduce the overhead for floating point. The results are illustrated with an FFT processor that performs 32, 64, 128, 256, 512, 1024 and 2048 point Fourier transforms with IEEE single precision floating point inputs and outputs. The design achieves sufficient density to realize a continuous complex data rate of 1.2 Gigasamples per second data throughput using a single Virtex4-SX55-10 device.
HPEC2006.pdf
36.75 KB, 下载次数: 184 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-11-6 20:51:17 | 显示全部楼层
发表于 2008-12-2 16:35:12 | 显示全部楼层
thank you
发表于 2008-12-6 11:15:49 | 显示全部楼层
学习学习
谢谢
发表于 2009-1-6 08:24:37 | 显示全部楼层
发表于 2009-1-15 16:42:03 | 显示全部楼层
谢谢啊!!!!
发表于 2009-1-15 22:30:54 | 显示全部楼层
thanks very much
发表于 2009-1-25 13:37:24 | 显示全部楼层
eetop对不起,您的操作将会导致您的 资产 低于系统规定的下限值 0 信元,请返回修正后重新提交。
发表于 2009-1-30 20:15:44 | 显示全部楼层
HAOHAOHAO
发表于 2009-2-27 10:29:40 | 显示全部楼层
不错,呵呵
GMT+8, 2025-10-27 06:08 , Processed in 0.027745 second(s), 8 queries , Gzip On, Redis On.
