查看: 4894|回复: 20
Power optimzation technique for charge pump design
发表于 2008-10-21 23:08:14 | 显示全部楼层 |阅读模式
A Power optimzation technique for charge pump design which acquires Drlington Award!
charge-pump circuits power-consumption optimization.pdf
423.67 KB, 下载次数: 146 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-10-22 02:15:36 | 显示全部楼层
good good
发表于 2008-10-22 03:00:32 | 显示全部楼层
thanks@@!!
发表于 2008-10-23 20:08:57 | 显示全部楼层
a good paper
thanks for sharing
头像被屏蔽
发表于 2008-10-27 19:55:50 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2008-11-6 15:55:23 | 显示全部楼层
IEEE TRANSACTIONS ON CIRCUITS AND SYSTEMS—I: FUNDAMENTAL THEORY AND APPLICATIONS, VOL. 49, NO. 11, NOVEMBER 2002
Abstract—In this paper, an optimized strategy for designing
charge pumps with minimum power consumption is presented.
The approach allows designers to define the number of stages
that, for a given input, and an output voltage, maximize power
efficiency. Capacitor value is then set to provide the current
capability required. This approach was analytically developed and
validated through simulations and experimental measurements on
0.35- m EEPROM CMOS technology. This approach was then
compared with one which minimized the silicon area and it was
shown that only a small increase in area is needed to minimize
power consumption.
Index Terms—Charge pump, integrated circuit (IC), power consumption,
voltage multiplier.
发表于 2010-1-13 14:48:59 | 显示全部楼层
haocailiao
发表于 2010-1-13 19:51:54 | 显示全部楼层
thanks
发表于 2010-1-13 20:39:02 | 显示全部楼层
thank you
下載來看看
发表于 2010-1-13 20:45:29 | 显示全部楼层
很好的资料~
GMT+8, 2025-12-25 11:24 , Processed in 0.023684 second(s), 9 queries , Gzip On, Redis On.
