楼主: benemale
『三味书屋』Artech House, Wiley , Cambridge Univ. 通信类书籍大放送
 楼主| 发表于 2008-10-7 22:07:26 | 显示全部楼层
Wavelet Transforms And Motion-compensated Temporal Filtering: Vlsi Architecture And Memory
by Liang-Gee Chen, Chao-Tsung Huang, Ching-Yeh Chen, Chih-Chi Cheng
[size=120%]Wavelet Transforms And Motion-compensated Temporal Filtering: Vlsi Architecture And Memory
By Liang-Gee Chen, Chao-Tsung Huang, Ching-Yeh Chen, Chih-Chi Cheng
  • Publisher:   Imperial College Press
  • Number Of Pages:   300
  • Publication Date:   2006-12-09
  • ISBN-10 / ASIN:   1860946739
  • ISBN-13 / EAN:   9781860946738
  • Binding:   Hardcover
[ 本帖最后由 benemale 于 2008-10-8 22:43 编辑 ]
Wavelet Transforms And Motion-compensated Temporal Filtering.rar
3.78 MB, 下载次数: 216 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-10-8 22:55:37 | 显示全部楼层
Coding Theory: A First Course
by San Ling, Chaoping Xing
[size=120%]Coding Theory: A First Course
By San Ling, Chaoping Xing
  • Publisher:   Cambridge University Press
  • Number Of Pages:   234
  • Publication Date:   2004-03-08
  • ISBN-10 / ASIN:   0521529239
  • ISBN-13 / EAN:   9780521529235
  • Binding:   Paperback
Product Description:
Concerned with successfully transmitting data through a noisy channel, coding theory can be applied to electronic engineering and communications. Based on the authors' extensive teaching experience, this text provides a completely modern and accessible course on the subject. It includes sections on linear programming and decoding methods essential for contemporary mathematics. Numerous examples and exercises make the volume ideal for students and instructors.
Summary: Excellent introduction
Rating: 4
Pros:
1. Rephrases of theorems in more understandable words other than just mathematical terms.
2. Use of analogy is particularly helpful.
3. Very readable proofs -- just about the right amount of details.
Cons:
1. Too many trivial examples in the first chapter.
Summary: Soft and pleasing intro to the (mathematical) coding theory
Rating: 5
A very soft introduction to coding theory. All the necessary information in finite field theory etc. are reminded of and short proves are also included. It is 25 years ago that I studied mathematics and it still was easy to follow. If you start from scratch you obviously have to invest some time to get a grasp of the mathematics before you can understand the application to coding.
After having read this book I finally know what this error messages of "Failed 312 cyclic redundancy checks" actually mean and why cyclic codes are used in physical networks (good burst correction properties).
If you want to dig deeper in the subject and you want to learn about nonlinear codes and more: than the authors tend to reference Neil J. A. Sloane, Florence Jessie MacWilliams "The Theory of Error-Correcting Codes".
[ 本帖最后由 benemale 于 2008-10-10 23:49 编辑 ]
Coding Theory - A First Course.rar
1.2 MB, 下载次数: 232 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-10-8 22:56:56 | 显示全部楼层
Understanding GPS: Principles and Applications, Second Edition
by Elliott D. Kaplan, Christopher Hegarty
[size=120%]Understanding GPS: Principles and Applications, Second Edition
By Elliott D. Kaplan, Christopher Hegarty
  • Publisher:   Artech House Publishers
  • Number Of Pages:   726
  • Publication Date:   2005-11-30
  • ISBN-10 / ASIN:   1580538940
  • ISBN-13 / EAN:   9781580538947
This thoroughly updated second edition of an Artech House bestseller brings together a team of leading experts who provide a current and comprehensive treatment of the Global Positioning System (GPS). The book covers all the latest advances in technology, applications, and systems. The second edition includes new chapters that explore the integration of GPS with vehicles and cellular telephones, new classes of satellite broadcast signals, the emerging GALILEO system, and new developments in the GPS marketplace. This single-source reference provides a quick overview of GPS essentials, an in-depth examination of advanced technical topics, and a review of emerging trends in the GPS industry. Engineers can use this book to build GPS receivers and integrate them into navigational and communications equipment. Executives can turn to this book to determine how technology is affecting markets and how best to invest their companies’ resources. The book also serves as a handy resource for electrical engineering students looking to advance their studies and careers in GPS.
Summary: GPS uses General Relativity
Rating: 5
[A review of the SECOND EDITION, 2005.]
In the last 15 years, GPS has moved from an expensive and specialised application to a mass consumer market. There are numerous books on GPS; mostly directly at that mass readership. These typically concern how to use a device with a GPS receiver.
By contrast, this book is meant for the engineer who has to design such a device. It is a compendium of technical papers covering many aspects you are likely to need. And undoubtedly some you won't, which should be reassuring. Because it means that you do not have to read all of this book for it to be useful.
The sensitivity of the GPS satellites and the resultant GPS ground resolution is amazing, as can be appreciated from some of the papers in the book. Due mostly to the stability of the satellites' orbits and their onboard atomic clocks. Chapter 7 describes how GPS requires corrections due to Einstein's Theory of General Relativity! Not just Special Relativity. As a physicist, I found this fascinating. GPS is perhaps the first field where General Relativity is used, not to be tested, but as providing a necessary quantitative model for getting correct results. Akin to how Newton's Equations have been used for 300 years in ballistics. Granted, most readers will be engineers, who might find GR a trifle exotic.
The book also has good coverage of the Russian GLONASS system. Perhaps for those who also want to use this for redundancy. Or to combine the signals from this with GPS for enhanced resolution.
Summary: Second edition in December 2005
Rating: 5
If you are looking at the first edition, please note that the publisher plans to issue a second edition in December 2005.
Summary: Great Technical Reference
Rating: 5
I'm an aerospace professional that is very close to the GPS system. This book is one of the best in depth references that I could recomend. I am not a novice and this text may intimidate some.
Summary: Great Book for Developing GPS Tracking Systems
Rating: 5
This is a great book to read if you plan on developing any type of GPS tracking system. While the book covers the the basics, you'll need some further resources on interfacing GPS receivers and such hardware to real-world devices. An interesting article entitled "Tracking a Vehicle With GPS" can be read at www.closerworlds.com A lot of mobile solutions are soon to hit the market such as mobile phones using GSM or GPRS to track a person. This book will help to understand how it all fits together. It would have been nice if the book could have touched on how older communication systems like VHF radios can transmit GPS data. For that you'll have to visit www.closerworlds.com or some other website with such resources.
Summary: Clearly the Best General Reference on GPS
Rating: 5
I've been an engineer and PM working with GPS and GPS systems since the inception of GPS in the mid-80s. While employed by a major DOD research lab I was fortunate enough not only to have access to practically every GPS book and article available, but I also had the opportunity to meet many of the key people responsible for the design and development of the system (many of whom contributed to this text). From system design to receiver architecture, this is by far the best general reference I have found on GPS.
[ 本帖最后由 benemale 于 2008-10-11 00:02 编辑 ]
Understanding GPS - Principles and Applications, Second Edition.part1.rar
3.81 MB, 下载次数: 176 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Understanding GPS - Principles and Applications, Second Edition.part2.rar
3.69 MB, 下载次数: 189 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-10-8 22:57:48 | 显示全部楼层
MIMO Wireless Communications
by Ezio Biglieri, Robert Calderbank, Anthony Constantinides, Andrea Goldsmith, Arogyaswami Paulraj, H.
[size=120%]MIMO Wireless Communications
By Ezio Biglieri, Robert Calderbank, Anthony Constantinides, Andrea Goldsmith, Arogyaswami Paulraj, H. Vincent Poor
  • Number Of Pages:   342
  • Publication Date:   2007-01-08
  • ISBN-10 / ASIN:   0521873282
  • ISBN-13 / EAN:   9780521873284
Multiple-input multiple-output (MIMO) technology constitutes a breakthrough in the design of wireless communications systems, and is already at the core of several wireless standards. Exploiting multipath scattering, MIMO techniques deliver significant performance enhancements in terms of data transmission rate and interference reduction. This book is a detailed introduction to the analysis and design of MIMO wireless systems. Beginning with an overview of MIMO technology, the authors then examine the fundamental capacity limits of MIMO systems. Transmitter design, including precoding and space-time coding, is then treated in depth, and the book closes with two chapters devoted to receiver design. Written by a team of leading experts, the book blends theoretical analysis with physical insights, and highlights a range of key design challenges. It can be used as a textbook for advanced courses on wireless communications, and will also appeal to researchers and practitioners working on MIMO wireless systems.
[ 本帖最后由 benemale 于 2008-10-11 00:09 编辑 ]
MIMO Wireless Communications.rar
3 MB, 下载次数: 280 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-10-8 23:04:29 | 显示全部楼层
thank you very much!
发表于 2008-10-9 05:58:10 | 显示全部楼层
非常感谢, 真想请你吃饭, 如果有机会, 一定。
发表于 2008-10-9 07:08:42 | 显示全部楼层
Amazing !!!!!!!!!  3X
发表于 2008-10-9 07:47:43 | 显示全部楼层
等了2天,爱死你了!
 楼主| 发表于 2008-10-9 08:15:33 | 显示全部楼层
原帖由 jacocobi 于 2008-10-9 05:58 发表
谢谢捧场,兄弟在国外吧,等你肥来再说吧。。。:lol :lol
现在只有晚上回家才有点时间上传,公司的蜗牛网慢死了。。。
发表于 2008-10-9 08:47:29 | 显示全部楼层
:victory:
怎一个谢字了得
GMT+8, 2025-12-29 23:30 , Processed in 0.025385 second(s), 4 queries , Gzip On, Redis On.
