查看: 4520|回复: 4
[求助]pcie 的驱动程序用什么软件开发?
发表于 2006-6-9 12:03:01 | 显示全部楼层 |阅读模式
看了一下driverstudio 3.2, 没有对pcie的支持。windriver不知行不行!难道用win ddk作?
发表于 2006-6-9 13:01:28 | 显示全部楼层
只是物理层变了,,而物理层由芯片组或者主板厂商提供,,
所以对于pcie设备,,沿用以前的开发流程和软件。。。
发表于 2007-1-4 09:07:46 | 显示全部楼层
YEAH, THE ANSWER IS CORRECT.
发表于 2007-1-4 12:35:51 | 显示全部楼层
原帖由 liuiang 于 2006-6-9 13:01 发表
嗯,基本上是透明的:
PCI compatible software model:
• Ability to enumerate and configure PCI Express hardware using PCI system configuration software implementations with no modifications
• Ability to boot existing operating systems with no modifications
• Ability to support existing I/O device drivers with no modifications
• Ability to configure/enable new PCI Express functionality by adopting the PCI configuration paradigm
发表于 2009-10-25 20:03:16 | 显示全部楼层
do you have reference source code in C?
GMT+8, 2025-12-22 23:31 , Processed in 0.022751 second(s), 6 queries , Gzip On, Redis On.
