查看: 5982|回复: 7
hspice2004.09 软件安装 请教
发表于 2008-9-3 20:06:12 | 显示全部楼层 |阅读模式
hspice2004.09以前可以安装,可以正常使用。
可是我重新覆盖系统之后,在安装hspice2004.09之后,却不能正常使用,方法和一样一样。这到底是为什么啊?
而把我的安装文件发到其他的机器上,同样的方法安装,却能够正常的使用。这到底是为什么啊??
装其他版本的hspice也是一样,请问这到底是什么问题,那位高手能指点下??
如下是出差错的信息
Init: read install configuration file: C:\synopsys\Hspice2003.09\meta.cfg
******  HSPICE    -- W-2004.09  (20040730) 19:45:57  09/03/2007  pcnt
  Copyright (C) 2004 Synopsys, Inc. All Rights Reserved.
  Unpublished-rights reserved under US copyright laws.
  This program is protected by law and is subject to the
  terms and conditions of the license agreement found in:
    C:\synopsys\Hspice2003.09\license.txt
  Use of this program is your acceptance to be bound by this
  license agreement. HSPICE is the trademark of Synopsys, Inc.
  Input File: e:\design and simulation\mod test\bsim3v3\dc simu\test3.sp
  lic: System clock has been set back FLEXlm error:  -88,309 For further informat
  lic: Bad date found on the running machine.
  lic: Has System date been set back? If not, Please
  lic: check files/dirs creation date on \ and \windows on PC.
  lic: Files/dirs creation date shouldn't have 24 hours
  lic: in the future or before 1970.
  lic:
  lic: FLEXlm: v8.4b
  lic: USER:   pan                  HOSTNAME: fe49a917b59a4ec
  lic: HOSTID: 000d60694b41         PID:      1224
  lic: Using FLEXlm license file:
  lic: C:\synopsys\Hspice2004.09\license.dat
  lic: Unable to checkout hspicewin
  lic:
  lic:
  lic: FLEXlm: v8.4b
  lic:
发表于 2008-9-4 01:20:40 | 显示全部楼层
是不是license过期了,或者你系统的时间不对
 楼主| 发表于 2008-9-4 09:53:13 | 显示全部楼层
恩  是的 是系统的时间没有调正确。
现在已经弄好了 非常感谢啊!!!
发表于 2012-5-4 20:15:48 | 显示全部楼层
回复 3# xwpan2005
    系统时间是指?怎么调?我也遇到同样的问题了~
发表于 2013-12-12 10:53:18 | 显示全部楼层
我也遇到同样问题了
发表于 2014-11-26 20:25:55 | 显示全部楼层
谢谢楼主了
发表于 2014-11-26 20:26:53 | 显示全部楼层
谢谢楼主了
发表于 2016-10-25 17:41:13 | 显示全部楼层
GMT+8, 2025-12-12 05:36 , Processed in 0.020172 second(s), 7 queries , Gzip On, Redis On.
