查看: 8488|回复: 30
Wide Range, Low Power Optical Preamplifier for Infrared and LAN Communications
发表于 2008-8-29 13:04:16 | 显示全部楼层 |阅读模式
1 INTRODUCTION......................................................................................................1
1.1 Overview.............................................................................................................1
1.2 Design Goals and Specifications........................................................................3
1.3 Review of Transimpedance Amplifier Designs..................................................5
1.4 Thesis Outline.....................................................................................................6
2 BACKGROUND........................................................................................................8
2.1 Conceptual Circuit Topology..............................................................................8
2.1 Stability...............................................................................................................8
2.2 Single-Ended Design........................................................................................10
2.3 Fully Differential Design..................................................................................11
2.4 Limitations of the Traditional Design...............................................................13
3 THE CLAMPING DESIGN.....................................................................................15
3.1 Motivation.........................................................................................................15
3.2 Implementation.................................................................................................15
3.3 Design Details and Simulation Results.............................................................17
3.4 Limitations........................................................................................................21
3.5 Summary...........................................................................................................21
4 THE SHUNTING DESIGN......................................................................................23
4.1 Motivation.........................................................................................................23
4.2 Implementation.................................................................................................23
4.3 Stability.............................................................................................................25
4.4 Design Details and Simulation Results.............................................................25
4.5 Discussion and Limitations...............................................................................28
4.6 Summary...........................................................................................................30
5 DYNAMIC BIASING..............................................................................................31
5.1 Motivation.........................................................................................................31
5.2 Dynamic Biasing Using Input Stage.................................................................32
5.2.1 Implementation.........................................................................................32
5.2.2 Small Signal Analysis...............................................................................34
5.2.3 Design Details and Simulation Results.....................................................35
5.2.4 Discussion and Limitations.......................................................................38
5.2.5 Summary...................................................................................................39
5.3 Dynamic Biasing Using Output Stage..............................................................40
5.3.1 Implementation.........................................................................................40
5.3.2 Small Signal Analysis...............................................................................41
5.3.3 Design Details and Simulation Results.....................................................42
5.3.4 Limitations................................................................................................49
5.3.5 Summary...................................................................................................50
6 CONCLUSIONS.......................................................................................................51
6.1 Summary...........................................................................................................51
Wide Range, Low Power Optical Preamplifier for Infrared and LAN Communications.pdf
1.23 MB, 下载次数: 228 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-9-3 08:38:14 | 显示全部楼层
看看什么东西
发表于 2008-9-3 08:39:27 | 显示全部楼层
thanks
thanks
发表于 2008-9-3 08:42:09 | 显示全部楼层
thanks
发表于 2009-1-19 01:17:24 | 显示全部楼层
多谢分享
发表于 2009-3-24 17:16:06 | 显示全部楼层
haven't download for a long time!
发表于 2009-7-12 12:06:39 | 显示全部楼层
7thanks for sharing
发表于 2009-7-16 21:23:23 | 显示全部楼层
谢谢了!!!
发表于 2009-8-13 22:41:04 | 显示全部楼层
dingyige,kankan
发表于 2009-9-7 16:13:19 | 显示全部楼层
学习下
GMT+8, 2025-10-5 12:54 , Processed in 0.032835 second(s), 7 queries , Gzip On, Redis On.
