查看: 3171|回复: 7
Morgan[1].Kaufmann.【VHDL】2008.Just.the.New.Stuff.Dec.2007.pdf
发表于 2008-8-3 11:21:07 | 显示全部楼层 |阅读模式
1Enhanced Generics 1
1.1Generic Types1
1.2Generic Lists in Packages6
1.3Local Packages11
1.4Generic Lists in Subprograms15
1.5Generic Subprograms21
1.5.1Uninstantiated Methods in Protected Types32
1.6Generic Packages36
1.7Use Case: Generic Memories43
2Other Major Features 53
2.1External Names53
2.2Force and Release63
2.3Context Declarations67
2.4Integrated PSL70
2.5IP Encryption77
2.5.1Key Exchange96
2.6VHDL Procedural Interface (VHPI)97
2.6.1Direct Binding97
2.6.2Tabular Registration and Indirect Binding99
2.6.3Registration of Applications and Libraries101
3Type System Changes 103
3.1Unconstrained Element Types103
3.1.1Composite Types103
3.1.2Subtype Indications and Constraints107
3.1.3Use of Composite Subtypes109
Variable and Signal Declarations110
Constant Declarations110
Attribute Specifications111
Allocated Objects111
Interface Objects112
Summary: Determining Array Index Ranges117
Type Conversions118
Alias Declarations and Subtype Attributes119
Resolved Composite Subtypes122
3.2Resolved Elements123
4New and Changed Operations 127
4.1Array/Scalar Logical Operations127
4.2Array/Scalar Addition Operators129
4.3Logical Reduction Operators 130
4.4Condition Operator132
4.5Matching Relational Operators133
4.6Maximum and Minimum138
4.7 Mod and Rem for Physical Types140
4.8Shift Operations141
4.9Strength Reduction and 'X' Detection142
5New and Changed Statements 143
5.1Conditional and Selected Assignments143
5.1.1Sequential Signal Assignments143
5.1.2Forcing Assignments146
5.1.3Variable Assignments147
5.2Matching Case Statements149
5.2.1Matching Selected Assignments150
5.3If and Case Generate151
5.3.1Configuration of If and Case Generate155
6Modeling Enhancements 159
6.1Signal Expressions in Port Maps159
6.2All Signals in Sensitivity List161
6.3Reading Out-Mode Ports and Parameters162
6.4Slices in Aggregates166
6.5Bit-String Literals167
7Improved I/O 169
7.1The To_string Functions169
7.1.1Predefined To_string Functions170
7.1.2Overloaded To_string Functions171
7.1.3 The To_ostring and To_hstring Functions172
7.2The Justify Function173
7.3Newline Formatting173
7.4 Read and Write Operations174
7.5The Tee Procedure177
7.6The Flush Procedure178
8Standard Packages 179
8.1The Std_logic_1164 Package179
8.2The Numeric_bit and Numeric_std Packages180
8.3The Numeric Unsigned Packages182
8.6The Standard Package191
8.7The Env Package192
8.8Operator Overloading Summary193
8.9Conversion Function Summary196
8.10Strength Reduction Function Summary204
Miscellaneous Changes
9.1Referencing Generics in Generic Lists207
9.2Function Return Subtype208
9.3Qualified Expression Subtype209
9.4Type Conversions209
9.5Case Expression Subtype211
9.6Subtypes for Port and Parameter Actuals212
9.7Static Composite Expressions213
9.8Static Ranges214
9.9Use Clauses, Types, and Operations215
9.10Hiding of Implicit Operations216
9.11Multidimensional Array Alias217
9.12 Others in Aggregates217
9.13Attribute Specifications in Package Bodies219
9.14Attribute Specification for Overloaded Subprograms
9.15Integer Expressions in Range Bounds220
9.16Action on Assertion Violations221
9.17 'Path_Name and 'Instance_Name 221
9.18Non-Nesting of Architecture Region223
9.19Purity of Now 223
9.20Delimited Comments224
9.21Tool Directives225
9.22New Reserved Words225
9.23Replacement Characters226
Whats Nex
10.1Object-Oriented Class Types229
10.1.1Standard Components Library232
10.2Randomization232
10.3Functional Coverage235
10.4Alternatives235
10.5Getting Involved235
Index
 楼主| 发表于 2008-8-3 11:23:12 | 显示全部楼层
Morgan[1].Kaufmann.VHDL.2008.Just.the.New.Stuff.Dec.2007.pdf
2.38 MB, 下载次数: 48 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-8-3 14:36:28 | 显示全部楼层
Thanks!!!
发表于 2008-8-3 20:02:46 | 显示全部楼层
嗯,是介绍VHDL发展趋势方面的内容
发表于 2008-8-3 22:40:45 | 显示全部楼层
Thanks.
发表于 2008-8-7 07:15:50 | 显示全部楼层
感谢楼主分享.
发表于 2008-12-9 19:18:26 | 显示全部楼层
re
good book, great support
发表于 2011-9-14 15:51:51 | 显示全部楼层
good book
GMT+8, 2025-10-26 05:07 , Processed in 0.022295 second(s), 4 queries , Gzip On, Redis On.
