查看: 16198|回复: 35
美资公司 LSI-Agere 上海研发中心高薪诚聘
发表于 2008-7-25 13:55:25 | 显示全部楼层 |阅读模式
美资上海研发中心高薪诚聘ASIC,Analog工程师(内部推荐)美资公司 LSI-Agere 上海研发中心高薪诚聘ASIC,Analog,Backend Place&Route,Product,Test工程师(内部推荐,成功机会更高)公司研发中心位于上海徐家汇高级写字楼,薪水待遇优厚,部分人员有出国培训机会。因公司发展需要,急聘存储和网络通讯领域以下职位(部分职位要求有所更新,digital IC design,Analog design空缺职位较多 )。有意者请将中英文简历发送至:rec_asic@live.cn
注:本人不是上海、杭州、南京、北京地区的高校毕业生,请大家不必担心简历投给熟人或同学手上的尴尬.希望大家投简历给我以后,就不要同时投给猎头了,由于猎头推荐给公司的人才被录用后,公司不得不向猎头支付不菲的中介费,所以公司通常会优先安排筛选和录用内部推荐的候选人,最后才会考虑猎头推荐的。如果简历不幸被猎头抢先投给公司,那么你的机会将大大降低,这是忠告!!公司的要求并没有那么高,如果有DSP,baseband demodulator, 视频解码芯片,音频解码,DVB demodulator,CMMB,图像处理,soc,ethernet, Read channel,等相关经历一至二年经验的都可以来试一试。论坛中已经有很多朋友获得了面试机会,甚至拿到了offer,我会继续为大家内部推荐,增加各位的成功机会,而且offer很可能会出乎你的意料。
 楼主| 发表于 2008-7-25 14:02:43 | 显示全部楼层
Requisition Number :  08-2961
Job Title :  Digital IC Design Engineer
Country :  China (CH)
State/Province/County :  Shanghai
City :  Shanghai
Requirements/Qualifications (Education) :
Job Qualifications:
- Communicate effectively within a global business environment (must be proficient in both spoken and written English)
- Experience in logic design, synthesis, static timing analysis, and verification
- Experience with ASIC EDA tools used in synthesis, simulation, static timing analysis, and formal verification
- Experience in developing simulation and verification test benches
- Knowledge of Verilog/VHDL design languages
- Excellent technical troubleshooting and demonstrated problem solving skills
- Must be willing to follow a structured design approach including design for reuse and provide thorough design documentation
Education/Certifications:
Required Degree: BS
Preferred Degree: MS or PhD
Preferred Major: Microelectronics, Electrical Engineering or related discipline
Job Description :  Position Description:
A read channel and hard-disk controller SoC digital IC design engineer's duties include working within a highly motivated product development team to create, modify and verify high speed digital integrated circuits. You will support the cross functional team in taking our concepts through to high volume production and assist us in becoming the market leaders in this Mass Storage (hard disk drive) industry.
Job Responsibilities:
- Working with a Architecture/Algorithm Development Team to finalize system architecture for optimal implementation of digital signal processing algorithms, including architectural definition and tradeoffs, die size estimation.
- Digital logic design, verilog coding, logic synthesis, both RTL and gate level verification, formal verification and static timing analysis.
- Perform some transistor level high speed digital integrated circuit design various cells and blocks within custom chips for the hard disk drive industry. Examples of cells and blocks include multiplexers, adders, multipliers, dividers, specific functional macro blocks,
- Work very closely with physical design engineers from floorplan through final parasitic extraction to ensure smallest area and highest performance possible.
 楼主| 发表于 2008-7-25 14:09:19 | 显示全部楼层
Requisition Number :  08-3117  Job Title :  Verification Engineer  Country :  China (CH)State/Province/County :  ShanghaiCity :  ShanghaiRequirements/Qualifications (Education) :  Functional/Industry Knowledge:Required:- Minimum of 2-6 years ASIC Verification experience in a product development environment- Proven ASIC Design Verification skills- Fluent in Verilog for design verification- Experience with Specman or System Verilog- Knowledge of data and telecommunication networking(TDM/IP/ATM/Ethernet)- Experience with one or more scripting languages: awk, Perl, python- Superior debugging skills for large ASIC designs- Strong written and verbal communication skills- Adaptable to evolving customer requirementsDesired:- Past experience in a lead position giving guidance to other engineers- Experience with C/C++Education/Certifications:Required Degree: BSPreferred Degree: MSPreferred Major: Electrical Engineering or related disciplineJob Description :  Job ResponsibilitiesDuties will include working within a Product Development Team to develop reusable block-level andASIC testbenches using HVL. Develop new ASIC verification environments to support ASICdevelopment. Maintain existing ASIC verification environments. Review RTL architectural andimplementation specifications. Create stimulus drivers, monitors, dataflow models, and test plans toverify function and performance of advanced multiprotocol networking ASICs. Define and developapplication tests required to verify ASICs meet functional and performance goals. Define andimplement functional coverage plans. Define and implement code coverage plans. Develop testing andregression methodologies for new verification flow. Coordinate test plan implementation andregressions with remote team. Incorporate reusability into all aspects of the verification environment.Develop/maintain/enhance environment tools/scripts/makefiles.
 楼主| 发表于 2008-7-25 14:16:34 | 显示全部楼层
Requisition Number :  07-2863
Job Title :  Analog IC Design Engineer
City :  Shanghai
Required:
- Minimum of 3-7 years Analog IC Design experience in a product development environment
- Perform transistor level, analog and mixed signal integrated circuit design of various cells and blocks
- Proven Analog IC Design skills
- Proven experimental skills and lab/bench expertise
- Strong written and verbal communication skills in both Mandarin and English
Desired:
- Past experience in PLL, High speed serial and deserial circuit.
Required Degree: BS
We value the diversity of our people. LSI is an Equal Opportunity Employer
Job Description :  Job Responsibilities:
Duties will include working within a Product Development Team to create (design, layout, and evaluate) new circuit architectures, and to modify existing circuit architectures, verify functionality of designs, prepare and present Design Reviews to internal groups and external customers, write technical reports, attend technical conferences in the areas of data storage and advanced IC design.
 楼主| 发表于 2008-7-25 14:19:52 | 显示全部楼层
Requisition Number :  08-3280
Department Name :  Read Channel Design and Integration
City :  Shanghai
Requirements/Qualifications (Education) :  Required Skills:
? Must be familiar with design concepts and architectures for complex analog signal processing functions including data conversion, switched-capacitor circuits, op-amps, pre-amps, comparators, filters, voltage and current references, phase-locked loops and their application to specific products.
? Experience in circuit design and layout of CMOS, BiCMOS or Bipolar silicon technologies as well as participation leading the development of IC projects is required.
? Experience with spice simulation and IC design CAD tools.
? Hard Disk Drive IC design experience is a plus.
Required Education:
? A minimum of a Masters degree in Electrical Engineering. PhD and/or 3 – 5 years of experience may qualify the candidate for consideration of a 8 or 10 grade level
Responsibilities:
Analog IC Design Engineers work closely with the design team and are responsible for developing design specifications, circuit topologies, performing circuit design, and proving out designs by simulation for storage IC’s from initial concept / specification through final verification of conformance to customer specifications. It also includes preparing block diagrams, schematics, simulation results and design analysis. Evaluate and help characterize prototype units. In addition support marketing in establishing custom IC requirements and providing estimation of new product development cycle time as well as participating in design review and technical discussion. Background should demonstrate good problem solving skills as well as strong intuitive ability and expert communication skills.
A qualified applicant for this position would be responsible for transistor level design and development as well as the modification, validation and evaluation of block architecture and/or the entire IC for hard disk drive applications. The position includes working with a design team including other Analog Designers, System Architects, Test Engineers, and Product Engineers to define, architect, and design CMOS PHY/SerDes IC’s utilized in the mass storage industry.
Full Time - Regular Employee
头像被屏蔽
发表于 2008-7-26 02:12:13 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2008-7-26 10:43:31 | 显示全部楼层
好有诱惑力
不过现值年破
不宜跳槽
 楼主| 发表于 2008-7-28 17:13:32 | 显示全部楼层
简历最好详细描述工作经验,必须有英文简历。
 楼主| 发表于 2008-7-29 17:43:41 | 显示全部楼层
这两天发的我都给manager和hr了
发表于 2008-7-31 23:09:40 | 显示全部楼层
我给你发了封简历!不知道有没有机会
GMT+8, 2025-12-21 19:30 , Processed in 0.025126 second(s), 6 queries , Gzip On, Redis On.
