楼主: jyuansea
delta-sigma adc
头像被屏蔽
发表于 2010-6-20 21:40:01 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2010-7-2 09:01:00 | 显示全部楼层
2# jyuansea
eetop.cn_Multi Bit SDM ADC.rar
File : pdf
Title : Design of Multi-bit Sigma-Delta Modulators for Digital Wireless Communications
Author : Bingxin Li
Year : 2003
Type : Submitted to KTH, Royal Institute of Technology, in partial fulfillment of the requirements for the degree of Doctor of Technology.
Abstract :
This thesis provides a comprehensive analysis of the solution
which combines a multi-bit quantizer with a 1-bit DAC in a sigma delta modulator.
Another topic addressed
in the thesis is how to reduce the multi-bit quantizer complexity.
发表于 2010-7-2 09:06:50 | 显示全部楼层
1# jyuansea
eetop.cn_A 50-MHz Multibit Sigma–Delta Modulator for 12-b 2-MHz AD Conversion.rar File : pdf Author : Brian P. Brandt, Student Member, IEEE, and Bruce A. Wooley, Fellow, IEEE Year : 1991 Type : IEEE Journal of Solid State Circuits Abstract : This paper examines the application of oversampling techniques to A/D conversion at rates exceeding 1 MHz. A cascaded multibit sigma-delta (2A) modulator that substantially reduces the oversampling ratio required for 12-b conversion while avoiding stringent component matching requirements is introduced. Issues concerning the design and implementation of the modulator are presented. At a sampling rate of 50 MHz and an oversampling ratio of 24, an implementation of the modulator in a 1-pm CMOS technology achieves a dynamic range of 74 dB at a Nyquist conversion rate of 2.1 MHz. The experimental modulator is a fully differential circuit that operates from a single 5-V power supply and does not require calibration or component trimmin
发表于 2010-7-2 09:20:07 | 显示全部楼层
感謝分享
发表于 2011-6-1 15:05:16 | 显示全部楼层
回复 1# jyuansea
    看看~~~
发表于 2014-1-23 16:18:59 | 显示全部楼层
good data
发表于 2014-1-23 16:23:39 | 显示全部楼层
tremdouslu useful
发表于 2014-2-5 13:54:58 | 显示全部楼层
good info
发表于 2015-3-7 15:43:15 | 显示全部楼层
delta-sigma adc
发表于 2016-8-24 10:55:41 | 显示全部楼层
delta-sigma adc
GMT+8, 2025-12-18 18:53 , Processed in 0.035974 second(s), 3 queries , Gzip On, Redis On.
