查看: 6636|回复: 21
Digital Clocks for Synchronization and Communications
发表于 2008-6-22 14:50:40 | 显示全部楼层 |阅读模式
If you need an in-depth understanding of the digital clock technologies used in building today??s telecommunications networks, this authoritative and practical book is a smart choice. Providing you with critical details on the PLL (phase-locked Loop) technique for clock synchronization and generation, and the DDS (direct digital synthesizer) technique for clock generation, the book helps you achieve synchronization in high-speed networks and frequency stabilization in portable equipment.
Covering both wired and wireless networks, the book looks at the combination of circuits and systems to give you a more thorough understanding of important design requirements. You learn important phase lock circuit design techniques, and how to select commercially available equipment for your projects in the field. A comprehensive presentation of frequency generation helps you make system/circuit design fluent and efficient. The book includes over 165 illustrations and 146 equations that support major topics.
Digital Clocks for Synchronization and Communications.pdf
2.27 MB, 下载次数: 115 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-6-22 22:41:53 | 显示全部楼层
thanks a lot
发表于 2008-6-23 06:28:14 | 显示全部楼层
3Q very much . i hope that i found those books
发表于 2008-7-7 06:46:18 | 显示全部楼层
Thanks you for share the theory about clock and digital communication
发表于 2008-7-10 11:27:56 | 显示全部楼层
发表于 2008-7-10 11:34:46 | 显示全部楼层
ding hao
发表于 2008-7-10 14:31:38 | 显示全部楼层
Thanks very much!
发表于 2008-12-7 13:33:16 | 显示全部楼层
thanks
发表于 2009-2-25 22:31:17 | 显示全部楼层
Thanks~~~
发表于 2009-2-25 22:55:52 | 显示全部楼层
thanks~~~
GMT+8, 2025-12-31 08:51 , Processed in 0.026948 second(s), 8 queries , Gzip On, Redis On.
