查看: 2017|回复: 6
Phase Loop Lock Design
发表于 2008-6-7 06:59:49 | 显示全部楼层 |阅读模式
To avoid the problems of the open-loop controller, control theory introduces feedback. A closed-loop controller uses feedback to control states or outputs of a dynamical system. Its name comes from the information path in the system: process inputs (e.g. voltage applied to an electric motor) have an effect on the process outputs (e.g. velocity or torque of the motor), which is measured with sensors and processed by the controller; the result (the control signal) is used as input to the process, closing the loop. Phase Loop Lock Design.pdf (409.79 KB , 下载次数: 20 )
发表于 2008-6-9 22:54:14 | 显示全部楼层
不错不错不错
发表于 2008-6-10 12:42:42 | 显示全部楼层
哦 还行...
发表于 2008-6-15 00:37:57 | 显示全部楼层
不错不错不错
发表于 2008-6-16 14:11:18 | 显示全部楼层
thanks
thanks
发表于 2008-6-16 14:12:29 | 显示全部楼层
thanks
发表于 2008-6-16 14:14:04 | 显示全部楼层
thanks
GMT+8, 2025-12-9 14:20 , Processed in 0.022418 second(s), 10 queries , Gzip On, Redis On.
