Phase compensation scheme for feedforward linearized CMOS OTA.pdf
Phase compensation for feedforward CMOS OTA.pdf
Miller OTA design using a design methodology based on the gm-id and early-voltage characteristics.pdf
Indirect feedback compensation of CMOS OpAmps.pdf
Efficient pole zero sensitivity analysis using asymptotic waveform evaluation.pdf
An NMOS OpAmp with internal compensation.pdf
A low dropout CMOS regulator with high PSR over wideband frequencies.pdf
A high performance low power CMOS channel filter.pdf |
