查看: 5651|回复: 15
Guide to ARMLinux for Developers
发表于 2008-5-20 21:00:39 | 显示全部楼层 |阅读模式
This guide is for developers working with GNU/Linux on ARM devices. Detailed set-up
instructions are given for the Delft Technical University LART, the Intel Assabet/Neponset
boards, and the Psion Series 5. However you can also use the book to help ARMLinux
development on any ARM device. A reasonable level of technical expertise is assumed, and
familiarity with Linux is helpful but not necessary
Webb W.Guide to ARMLinux for developers.2002.pdf
1.26 MB, 下载次数: 110 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2008-5-22 09:34:34 | 显示全部楼层
thanks for the sharing
发表于 2008-5-28 23:55:57 | 显示全部楼层
支持一个
发表于 2008-6-22 11:18:01 | 显示全部楼层
Arm , Most mobile system use it . Thanks those metariel
发表于 2009-4-14 17:17:29 | 显示全部楼层
谢谢楼主,
发表于 2009-10-22 21:35:39 | 显示全部楼层
xie xie le
发表于 2009-10-23 22:37:16 | 显示全部楼层
thank yoU!
发表于 2009-10-23 22:45:25 | 显示全部楼层
Thank you!
发表于 2010-5-17 10:53:45 | 显示全部楼层
学习。。。谢谢。。。
发表于 2010-5-17 22:40:50 | 显示全部楼层
Take a look
GMT+8, 2025-11-21 00:02 , Processed in 0.023392 second(s), 6 queries , Gzip On, Redis On.
