楼主: liulijun365
为何模拟地和数字地要分开?
发表于 2012-5-3 11:00:52 | 显示全部楼层
说的还不够详细!!
发表于 2012-5-7 22:06:42 | 显示全部楼层
接到一起最好用磁珠连接
发表于 2012-5-11 20:31:36 | 显示全部楼层
分析的有道理
发表于 2012-5-14 01:45:22 | 显示全部楼层
AGND/PGND can be shorted together directly, but since most ICs may already have an internal connection, if you short them together again in PCB, you will create a ground loop, hence you need to know how your IC is internally connected, and chose a anti-parallel short in PCB design if the two grounds are directly shorted together in the IC internally; or a direct short if the grounds are shorted internally by two anti-parallel diodes
GMT+8, 2025-12-23 01:01 , Processed in 0.013783 second(s), 3 queries , Gzip On, Redis On.
