在线咨询
切换到宽版
EETOP 创芯网论坛 (原名:电子顶级开发网)
  登录   注册
快捷导航
查看: 179|回复: 1
[求助] 瞬态仿真不收敛
发表于 2024-4-24 20:44:31 | 显示全部楼层 |阅读模式
小弟在仿真一个RF-DC整流器,频率915MHz,在进行瞬态仿真的时候出现警告和报错如下:
Warning from spectre at time = 320.599 fs during transient analysis `tran'.
    WARNING (SPECTRE-16266): Error requirements were not satisfied because of convergence difficulties.
Warning from spectre at time = 522.948 fs during transient analysis `tran'.
Warning from spectre at time = 599.629 fs during transient analysis `tran'.
Warning from spectre at time = 656.411 fs during transient analysis `tran'.
Warning from spectre at time = 714.594 fs during transient analysis `tran'.
        Further occurrences of this warning will be suppressed.
Warning from spectre at time = 6.0953 ps during transient analysis `tran'.
    WARNING (SPECTRE-16191): Minimum time step used.  Solution might be in error.
Error found by spectre at time = 6.21498 ps during transient analysis `tran'.
    ERROR (SPECTRE-16927): Transient simulation reaches maximum allowed number of convergence failures below minstep within 5% of stop time.
        Change option `max_minstep_nonconv' to adjust the allowed maximum number of convergence failures below minstep.
Last acceptable solution computed at 6.21498 ps.
瞬态仿真的精度在设置为conservative和moderate均出现上述错误,当设置为liberal仿真可以正常运行;
想问问导致这个错误的原因是什么?有什么方法可以解决?如果我使用liberal进行瞬态仿真得到的结果能用吗,会不会因为精度低导致结果错误?感谢各位解答!!!!
 楼主| 发表于 2024-4-24 22:09:13 | 显示全部楼层
找到原因了,是我的地连接的有问题,感谢
GMT+8, 2024-5-6 13:33 , Processed in 0.018801 second(s), 7 queries , Gzip On, Redis On.
