INFO (verilogIN-589): Using ncvlog binary for compilation.
ERROR (VERILOGIN-28): Failed to run the ncvlog analyzer because the analyzer binary could not be located.
Either the analyzer binary does not exist in the shell search path or you do not have the required permissions on the file. Set the correct shell search path and update the file permissions before running the command again.
ERROR (VERILOGIN-5): Unable to open the specified log file (ncvlog.log) for reading. Either the file does not exist or you do not have read permission on the file.
INFO (VERILOGIN-206): End of Logfile.
