查看: 12246|回复: 16
[求助] cadence仿真波形是很细的虚线,有大佬知道如何设置吗
发表于 2021-3-11 21:37:10 | 显示全部楼层 |阅读模式
 楼主| 发表于 2021-3-11 21:38:55 | 显示全部楼层
发表于 2021-3-12 09:25:44 | 显示全部楼层
同问,有时候我也会出现这种情况
发表于 2021-3-12 13:05:18 | 显示全部楼层
try this
The display.drf file can be modified to change the plotting behavior.
This will apply to signals plotted from ADE.
1. Open Display Resources Manager in CIW by selecting "Tools ->Display Resources Manager...“
2. Click "Edit..." in Display Resources Tool Box.
3. Change "Tech Lib Name" to your technology library.
4. Search for layer "y0 drawing" and modify the Line Style and click "Apply" at the bottom of "Layers" column.
5. Re-do step 4 to change "y1", "y2" ........ "y9" drawing layers.
6. File->Save in the Display Resource Editor.
7. Load this in your CIW with "drLoadDrf "./display.drf" command
after your pdk display.drf file is loaded.
For standalone ViVA environment variables should be set in the .cdsinit
or .cdsenv files, i.e.
• viva.trace lineStyle string "solid" nil
• viva.trace lineThickness string "thick" nil
A full list can be found in this file $CDSHOME/tools/dfII/etc/tools/viva/.cdsenv
回复 支持 9 反对 0
发表于 2021-3-12 13:25:20 | 显示全部楼层
选中波形,右键设置 style--->solid
 楼主| 发表于 2021-3-12 14:50:13 | 显示全部楼层
david_reg 发表于 2021-3-12 13:05
try this
This will apply to si ...
thanks a lot
发表于 2022-3-28 13:58:24 | 显示全部楼层
所以楼主看这个解决了虚线的问题了吗
 楼主| 发表于 2022-4-2 17:11:11 | 显示全部楼层
喵星人在et 发表于 2022-3-28 13:58
所以楼主看这个解决了虚线的问题了吗
nononono
发表于 2023-4-6 23:16:54 | 显示全部楼层
每一次都得style
发表于 2023-7-27 20:45:05 | 显示全部楼层
也可以在ciw窗口写命令,这样不用每次都右键选style-solid。
GMT+8, 2025-12-19 09:56 , Processed in 0.023511 second(s), 4 queries , Gzip On, Redis On.
