查看: 11319|回复: 29
[资料] Design and analysis of folded cascode OTAs using Gm-Id methodology based on flicker noise reduction
发表于 2020-12-9 18:06:51 | 显示全部楼层 |阅读模式
Design and analysis of folded cascode OTAs using Gm/Id methodology based on flicker noise reduction
Published: 17 April 2015
Abstract: In this paper, a new methodology for design of folded cascode (FC) and recycling folded cascode (RFC) OTAs based on 1/f noise reduction is presented. With a new formulation for input referred flicker noise based on Gm/Id characteristic in all operation regions significantly enhance of the noise performance is achieved. Also, this technique leads to the larger DC gain and gain-bandwidth, and phase margin degeneration. The amplifiers were simulated in the 0.18 μm CMOS technology and the simulation results confirm the theoretical analyses. Proposed design methodology exhibits 50 % reduction of input voltage noise @ 1 Hz for RFC compared to the FC amplifier, without increasing the power consumption and silicon area.
https://link.springer.com/article/10.1007/s10470-015-0535-x
Design and analysis of folded cascode OTAs using Gm-Id methodology based on flic.pdf (1000.68 KB , 下载次数: 296 )
发表于 2020-12-9 18:35:57 | 显示全部楼层
thanks!!!
发表于 2020-12-9 21:22:25 | 显示全部楼层
thanks
发表于 2020-12-9 22:17:54 | 显示全部楼层
kankan
发表于 2020-12-10 10:36:16 | 显示全部楼层
感谢
发表于 2020-12-10 11:25:35 | 显示全部楼层
thanks
发表于 2020-12-10 14:56:14 | 显示全部楼层
好好好
发表于 2020-12-10 15:20:42 | 显示全部楼层
Thank you
发表于 2020-12-10 16:49:34 | 显示全部楼层
好好学习一下。
发表于 2020-12-10 19:56:48 | 显示全部楼层
good topic
thank you
GMT+8, 2025-12-14 14:56 , Processed in 0.019672 second(s), 4 queries , Gzip On, Redis On.
