各位大哥帮忙看一下
check_ibrary的时候出现了一些问题:
1、Warning: target_library "tcb018gbwp7tlt_ccs.db tcb018gbwp7twc_ccs.db" ignored when -logic_library_name is specified
Warning: link_library "* tcb018gbwp7tlt_ccs.db tcb018gbwp7twc_ccs.db standard.sldb dw_foundation.sldb" ignored when - logic_library_name is specified
2、Warning: List of cells with mismatched or missing attributes in logic libraries (LIBCHK-311)
这个下面好像是列举了10个有问题的cells
3、Warning: List of pins with mismatched or missing attributes in logic libraries (LIBCHK-321)
这个下面列举了好几页的pin的问题
4、Library 1 is non-pg_pin library.
Library 2 is non-pg_pin library.
5、Warning: slew/load index mismatches found.
6、Warning: List of inconsistent power models. (LIBCHK-341)
这个下面列举了三个
7、Number of cells checked 560
Number of cells passed 558
缺了两个
8、Number of cells missing in logic library: 1 (out of 1120)
9、Information: List of physical only cells (LIBCHK-119)
下面列举了7个filler
10、Warning: List of cells with cell_footprint attribute (LIBCHK-215)
下面又是好几页的列表
11、Logic vs. physical library check summary:Number of cells missing in logic library: 1
Information: Logic library is INCONSISTENT with physical library (LIBCHK-220)
12、Warning: The library is missing signal EM data.
13、Warning: The library is missing antenna rules. (LIBCHK-116)
No cells are missing antenna properties in the library.
14、Error: Mismatched and missing data found. Please refer to LIBCHK-122. (LIBCHK-101)
15、Warning: Layer 'METAL1' has a pitch 0.56 that does not match the recommended wire-to-via pitch 0.535. (TFCHK-049)
Warning: Layer 'METAL2' has a pitch 0.56 that does not match the recommended wire-to-via pitch 0.61. (TFCHK-049)
Warning: Layer 'METAL5' has a pitch 0.56 that does not match the recommended wire-to-via pitch 0.61. (TFCHK-049)
Warning: Layer 'METAL6' has a pitch 0.9 that does not match the recommended wire-to-via pitch 0.95. (TFCHK-049)
Warning: Layer 'METAL3' has a pitch 0.56 that does not match the doubled pitch 1.12 or tripled pitch 1.68. (TFCHK-050)
Warning: Layer 'METAL4' has a pitch 0.56 that does not match the doubled pitch 1.12 or tripled pitch 1.68. (TFCHK-050)
Warning: Layer 'METAL5' has a pitch 0.56 that does not match the doubled pitch 1.12 or tripled pitch 1.68. (TFCHK-050)
Warning: Layer 'METAL6' has a pitch 0.9 that does not match the doubled pitch 1.12 or tripled pitch 1.68. (TFCHK-050)
Warning: CapModel sections are missing. Capacitance models should be loaded with a TLU+ file later. (TFCHK-084)
